5th gear is noisier because of the design of the gears and they way they mesh ( 5th gear on a 6 speed, 4th on a 5 and 3rd on a 4 are stronger than the top gear and used for pulling, passing etc.).
You can try a fix in a bottle, but you may find that it is just a part of the animal.
of course is this is a new noise that wasn't there few weeks ago, then further investigation is called for.
there are few things more surprising than the tranny locking up
if you google:
2010-model-year-technical-forum.pdf
you will find a nice diagram of the gears in the tranny on page 3
Like posted above, if the noise isn't "new", don't worry about it. 5th is a straight cut gear and has "gear whine". It's normal and as it should be. The only cure is helical cut gears that Harley went to in, I believe, '11. They are quieter, but not as strong.
i have a 07 ultra classic six speed. fifth gear is noisy. i am looking for a fix to this problem. any help would be appreciated
The Redline made a big difference in mine .... but as others have stated the noise is caused by the way fifth gear is cut ( Genius' at H.D. ) and it really is nothing to worry about. If you're really concerned go out get a 2010 or later bike ( They finally fixed the problem )
