Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Softail Primary Chain and comp sprocket
Old Jun 18, 2010 | 02:29 PM
IronButt62's Avatar
IronButt62
Default Softail Primary Chain and comp sprocket
Just tried to fit a 23T comp with an 80 link chain on my 05 Primary.
Stock for late model is 25T Comp 36 Clutch 82 link chain.
23T and 24T Comp will work with stock adjusting shoe, but not Hayden M6 Tensioner.
80 link chain and 23T Comp will not work.
I am liking the 23/36 with the 6 speed.
Hope this helps someone some day.
Deet
Old Jun 19, 2010 | 12:45 PM
soft 02's Avatar
soft 02
Good info. is it the same as the 07's. What did it do to fuel mileage?
Old Jun 19, 2010 | 06:48 PM
buckfxstc's Avatar
buckfxstc
5th Gear
I am trying to solve a vibration problem with my 97 fxstc. The bike has 22k miles on it, i had new tires put on it @ 6k ago, for the past 2-300 miles i have started with a vibration, first on bars now on pegs, was told drive belt was too tight, adjusted ..no better, primary was loose, adjusted a little better...could the tight belt have harmed the transmission??? causing vibrations?
thanks'
Old Jun 20, 2010 | 12:34 AM
soft 02's Avatar
soft 02
buckfxstc does it go away when you pull the clutch?
Old Jun 20, 2010 | 01:13 AM
buckfxstc's Avatar
buckfxstc
5th Gear
yes...
Old Jun 20, 2010 | 01:14 PM
IronButt62's Avatar
IronButt62
Haven't checked mileage yet. Probably won't be too accurate though. The 23/36 is much more responsive than the 25/36 and has led to an uncontrollable quick rotation of the throttle on numerous ocassions... followed by a big *** grin!
I did notice (as expected) that the RPM at speed went up. 3000 RPM used to get me low 80's... now it's high 70's which is still fine.
sandlug
13
Feb 25, 2017 04:38 PM
Seventy4blazer
Jun 6, 2016 09:09 AM
Matt Stone
Jun 2, 2015 02:32 PM
61flh
EVO
Jan 7, 2014 08:55 PM
StrikeZone
Mar 5, 2013 01:42 PM
