Stripped tranny drain plug
I got recommendations from an indy and a dealer to get an oversized drain plug from an automotive supply place. No luck finding the right one so far.
I used to work on air cooled motors in cars in my earlier days and they made steel inserts to fix this problem, wherein you drilled and tapped the hole to an oversize for the insert and screwed and locked it in, allowing the stock plug to be used. Haven't been able to find such a beast for my HD yet.
Any suggestions?
BTW, 07 Fatboy with 6 speed tranny.
Over sized drain plugs are very common and I don't understand why you can't find one. They come in several sizes. The original thread is a 1/2 x 20, but....if you can't find an over sized one...I would just tap it out for a larger bolt (fine thread) and use a felt washer. That is all the over sized plug does anyway...just cuts larger threads in the same pitch. A tap will likely not be that much more/less expensive that a thread insert kit. Or, tap the hole out to a pipe plug (NPT).
If you buggar this thing up bad enough...you may wind up taking the pan off anyway to make sure this gets done right.
Consider review of link bellow.
http://www.bigboyzheadporting.com/showthread.php?t=85
Look inside the drain hole..sometimes there is A LOT of thread available much higher/deeper.
Might consider using a longer PILOT POINT drain plug in same original factory size.
Options mentioned will not permit use of original factory o-rings but you could use the metal framed rubber washers that are hanging right next to the oil drain plugs.
The article in link above is correct about the o-ring on the piggy back moving.
The piggy back also has a larger head and sits lower on some bikes which may cause a problem with motorcycle jacks.
The longer bolt would seem the least damaging.
I have worked with the oversized myself.
And as many of us have learned the hard way:
The oil drain plug requires very little torque..A little past finger tight.
My background in mechanics was working on cars, and specifically VWs, a number of years ago and occasionally, the odd bike here and there. I have used both heli-coils and different inserts in an aluminum based material with varying success. For this application, the only insert I would have considered is a hat style where the hat shoulder bottoms against the original surface locking it in. I know there is enough material there for the type I was thinking of to have worked, and considering the 2" wide shocks set below the bolt head, I wasn't worried about dragging it. Helicoils, expecially the non-bottoming kind, never seem to work well in an aluminum type material due to differences in heat expansion properties.
In the intervening time when I wasn't in the business, obviously they have had some technology improvements so seeing the oversize drain plugs referenced definitely tells me where to go with this. I wasn't sure what the single oversize, double oversize, piggy back references meant until I saw the link. I ran a 1/2-20 bottoming tap through it last night, rinsed it through with some clean kerosene, and tried to tighten it up; had the torque wrench set to 60 in/lb and it never got close to clicking before the last remaining thread or two gave way. I'm headed out to find the right oversize plug today.
Thanks all.
I know better... in my current profession, safety rules and there is no such thing as "maybe". I was just stupid the other night and now I'm paying for it.
