Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Noise
Old Aug 11, 2010 | 04:46 PM
masplumber's Avatar
masplumber
Default Primary Noise
Set out for a short run friday and after couple miles i noticed a louder than normal noise from the left side. Stopped to check and it sounded like the clutch was partially engaged, definatly a lot of clanging, whinning goin on. Vibration was pretty intense so i headed for the dealer. I asked the service tech to give it a listen and he says it sounds like the compensator nut is loose and recommended not to drive too far. So i ask when they can fix it and he says bring it in wednesday (today) and i could get it back maybe saturday. So i'm not real happy with the dealer but i'm concerned about a loose nut causing all that noise and vibration. Anybody have any input?
Old Aug 11, 2010 | 08:43 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
If the comp nut is loose and touches the cover it will screech like crazy. Best not to drive it much until you can open it up and check it.
Old Aug 17, 2010 | 06:54 AM
masplumber's Avatar
masplumber
Default Update
Just picked bike up from dealer. Tech tells me a tooth on the clutch sprocket sheared off and had initially wedged behind front sprocket causing the squealing noise until it dropped out. I'm not a rocket scientist but that can't be a good thing. What would cause a tooth to break or shear off and has this happened to anybody else?
hd_doctor
Jul 28, 2018 03:32 PM
diverherb
Oct 27, 2016 10:40 AM
2kids3pets
Apr 3, 2015 02:25 PM
Traceman
Sep 13, 2009 06:03 AM
kwk4899
Sep 25, 2008 11:46 AM
