Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Evo with a 4 speed kickstart??
Old Oct 5, 2011 | 03:12 PM
drewolf's Avatar
drewolf
2nd Gear
Default Evo with a 4 speed kickstart??
Hi Guys
My first post here - be gentle.
I'm intrigued by a bike for sale here in Cape Town, South Africa.
It's a custom softail with a 1340 evo motor running through a 4 speed kickstart transmission.
That's not stock right?
It's selling for not too much cash and looks like it could be the start for a cool project bike I have in mind.
Any opinions on the engine/gearbox combo?
There's a few other things too:
Builder says it has a Custom softail frame 58-84 - what do those numbers mean?
The primary is described as a 'cut down' style which 'means no oil leaks here' - opinions on that too please.
Thanks for the time fellas, look forward to the replies......
Cheers.
Drew
Old Oct 10, 2011 | 03:40 AM
grbrown's Avatar
grbrown
Hi Drew and welcome to HDF from the UK. This Tech forum doesn't get many visitors so I suggest you post again in the Evo section, where you will find our experts on early Evos. Some very early Evos had 4-speeds, as far as I know, so that bike may be fine from that point of view. It would help if you can post some photos on another website and give us a link, so we can a look at this bike, but do that over in the Evo section.
Old Oct 10, 2011 | 07:18 AM
ajayrk's Avatar
ajayrk
1984 was the first year of the Softail and it had the EVO with a four speed transmission.
http://www.harley-davidson.com/wcm/C...p?locale=en_US
http://www.hemmings.com/hmn/stories/...feature11.html
Old Oct 10, 2011 | 07:25 AM
nvsteve's Avatar
nvsteve
Also had kickstart on some models. A buddy has had one since new.
Old Oct 11, 2011 | 08:20 PM
pjb's Avatar
pjb
all 1984 and 1985 softails had evos and 4 speed kickstarts. there only was the FXST softail, no other variations of softail. 1986 started the FXSTC and the Heritage model softail. In 1986 all softails had the 5 speed with no kickers.
The 1985 and 1986 Wide Glide (FXWG) had the evo with the 4 speed kickstart, and was the last of any kickstarts for harley.
Old Oct 12, 2011 | 04:02 AM
drewolf's Avatar
drewolf
2nd Gear
Thanks for the info, fellas.
I'll post a pic of the bike over in the EVO section.
I've found out a bit more:
Frame is a Santee, '84 EVO motor with 4spd kick only, 4" over fork, drag pipes, mustang tank. I hope to be taking delivery saturday.
Old Oct 12, 2011 | 05:27 AM
pjb's Avatar
pjb
I should have added - all the 4 speed kickstart evos had electric start from the factory also. as you have already pointed out, your bike is not stock.
My evo can be a beast to kick over, not sure I would want to have to do it all the time. good ignition is critical to easier kick starting.
dan1869
Aug 3, 2021 07:19 PM
Notgrownup
Aug 3, 2012 11:11 AM
drewolf
EVO
19
Oct 18, 2011 05:49 AM
bikerlaw
EVO
Aug 30, 2011 08:29 PM
phatsanders
Sep 6, 2009 02:50 PM
