Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch Noise and adjustment Question.
Old May 21, 2012 | 12:06 PM
Goose 915's Avatar
Goose 915
Default Clutch Noise and adjustment Question.
I have a 2012 Road Glide Custom with 2300 miles on it and have a question about the clutch. I recently had the 1000 mile service done and the tech said he adjusted the clutch but I am noticing that the lever has tons of slack in it and doesn't return completely when released and there is some noise coming from the primary when the lever is not pulled in but stops when I pull the lever in. Is this noise something that can be resolved by properly setting slack in the cable or should I check pushrod adjustment and then set cable slack? Thanks for any help.
Old May 22, 2012 | 03:49 PM
corliss@bakerdrivetrain.com's Avatar
What is tons of slack? There should be about 1/8 inch of free play.
Old May 23, 2012 | 05:49 PM
first dyna 07's Avatar
first dyna 07
No if they adjusted the rod then you just do the cable it will only be a 1/2 a turn a most
Gidon
Jan 12, 2019 07:37 PM
LovelaceJR
Feb 14, 2016 06:15 PM
GPHDXLC
May 25, 2012 10:06 AM
Rich G.
Ironhead
Dec 30, 2008 09:57 PM
MAX EVO
Nov 14, 2007 03:31 PM
