Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Shifting problem
Old Jun 11, 2012 | 08:38 AM
artmo's Avatar
artmo
Stage II
Default Shifting problem
I have a 83 Flht W/sidecar, The engine is rubber mounted with a 5 speed, when I shift up it is hard to get into gear and when I shift down it acts normal. I tried adjusting the clutch and readjusted it, so it seems that is not the problem, well maybe?. Does anyone have any suggestions on this problem. Thanks for your help. Art my email is artmo@nycap.rr.com
Old Jun 11, 2012 | 01:07 PM
corliss@bakerdrivetrain.com's Avatar
Check your linkage from the shift pedal to the shift lever on the trans for binding.
Old Jun 11, 2012 | 06:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
In addition to Mark`s suggestion, grab the shift lever at the transmission and make sure it is secure, sometimes they get loose and slip on the splines causing shifting problems (this in not uncommon).
If everything is secure and moving freely, check the adjustment of the shifter pawl, it is explained in the service manual.
mlburchjr
2014-2024 Touring Models
Jul 4, 2016 07:27 PM
HAP76
Jul 20, 2012 09:03 AM
Tompop
Jul 8, 2012 06:48 PM
lagrato
Apr 4, 2010 07:50 AM
rollmeaway
Sep 23, 2007 11:16 AM
