Downshifting problems
Old Jul 3, 2016 | 08:26 PM
mlburchjr's Avatar
mlburchjr
4th Gear
Default Downshifting problems
I am having an issue with downshifting. I have a 2016 Limited and just had the 1000 mile service done. I had the dealership put Syn3 in. I usually use the engine braking technique and everything works fine, however, every once in awhile I will keep the clutch in and shift all the way to first. The shift lever moves and shifts down one gear but won't shift any further. When I come to a stop I can shift down to first. This issue didn't exist prior to the service. I checked the fluid level and it is good. During the service they also changed the shift levers and linkage. This seems like it could be dangerous in an emergency braking situation. Any help would be appreciated.
Thanks
Mark
Old Jul 3, 2016 | 09:32 PM
mikeman54's Avatar
mikeman54
How fast you going when you shift all the way down to first. One gear at a time until RPMs come down.
Old Jul 3, 2016 | 10:30 PM
BigEd04's Avatar
BigEd04
Take it back. It's not adjusted correctly. Emergency/rapid stop technique as taught by MSF has you go all the way down rapidly so as to be in 1st when you get stopped or slow enough to swerve. Sounds like it's under a bind.
Old Jul 4, 2016 | 10:58 AM
GTK's Avatar
GTK
Since you stated they changed the shift lever and linkage,could it be the lever is in a slightly different position and your not letting lever return so shift pawl can select next lower gear?
Old Jul 4, 2016 | 07:10 PM
mlburchjr's Avatar
mlburchjr
4th Gear
It was the shift rod. I compared the new one to the stock one and the new one was almost an inch longer. I corrected it and the issue has been solved. Thanks for the advice.
Old Jul 4, 2016 | 07:27 PM
muddmann's Avatar
muddmann
Yup, take it back.
P51Driver
2018+ Softail Models
21
Jun 22, 2019 09:10 AM
aaron8771
Nov 28, 2012 07:17 PM
Nick
Aug 24, 2012 02:03 AM
artmo
Jun 11, 2012 06:38 PM
Babs
17
Feb 8, 2007 10:48 AM
