Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Speed Sensor Pickup Problem (pics)
Old Aug 14, 2005 | 03:41 PM
HDF Tech's Avatar
HDF Tech
Default Speed Sensor Pickup Problem (pics)
This will show the magnetic speed sensor pick up and how it gets fouled from the metal shavings in the transmission which causes the speedo to stop working and the directionals to stop self canceling because of no input to the ECM from the sensor. The ECM thinks that the bike is standing still because of no input. It will also set a code which gives you a red light on the dash.
Use of a good gear oil will almost eliminate this problem completely.
Also see below *Speed sensor pick up problems* ... HERE
And this post... HERE
The 06 bikes no longer advise use of Syn 3 in the trans from HD
[IMG]local://upfiles/2318/F933F72062FD4A28AF1FFB95716E66BD.jpg[/IMG]
olelucky
Jan 1, 2015 03:47 PM
Brook Allen
Aug 13, 2013 05:20 PM
shakrr
Mar 31, 2013 07:22 PM
Dirty Dan
Apr 3, 2008 01:01 PM
HDF Tech
Jul 14, 2005 08:57 PM
