Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
OK
I need some Help I am my chain Tensioner & I forgot to get the cover boltpattern andBoltTorque so will one of you Help me out I try-ed to buy a manualfrom 3 Dealers theywere out so I ordered one,but I need help now
06 Ultra Classic 8 months old and have 19950 miles on her
I'm assuming you are referring to the 4 bolt primary chain inspection cover?
My '05 manual ('06 the same?) has the pattern to be top right bolt (1), bottom left bolt (2), bottom right (3), top left (4).......84 - 108 in/lbs
The Chain tensioner top center nut to be torqued to 21 thru 29 ft/lbs.
