Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Neutral Problem
Old Mar 18, 2007 | 01:55 AM
Taterdog's Avatar
Taterdog
Default RE: Neutral Problem
Just ordered both MTL and Heavy Shockproof from the link you provided. Thanks guys.
I'll let you know how it turns out once I receive it next week.
Old Mar 18, 2007 | 11:50 AM
Lovtoride's Avatar
Lovtoride
Manual says improper fluid level
Old Mar 18, 2007 | 12:24 PM
Taterdog's Avatar
Taterdog
Yep, could be. Plan to check that when I change the fluid.
Old May 5, 2007 | 11:28 PM
Taterdog's Avatar
Taterdog
Since my last post I've been running Redline MTL in the primary and Heavy Shockproof in the tranny. Anyway, still been having problems finding neutral.
Adjusted the clutch today, and with the bike cold it went in easy peasy, but once the bike warmed up I was back to the same old problem. Bike shifts great, but still have a really hard time finding neutral. Fluid level is right on, so don't think that's the problem.
My question: Since I was able to find neutral with the bike cold but had problems once it warmed up, what does that indicate? I backed the clutch adjuster screw out 1/2 turn after I had slight resistance -- should I have backed it out a full turn?
I've got to be getting close, but don't know which way to go to make the adjustment. Anyone have an idea what I should do next?
Old May 5, 2007 | 11:41 PM
Chief101's Avatar
Chief101
taterdog, pm me
Redlegvzv
Oct 29, 2015 09:19 AM
tmoney1
Mar 22, 2013 03:40 PM
ga guy
11
Aug 1, 2010 11:09 AM
dennisaa
Feb 19, 2007 01:01 AM
BigKat
Apr 1, 2006 02:39 AM
