Ride Planner
Old Aug 5, 2020 | 12:53 PM
quadmania's Avatar
quadmania
Default Ride Planner
I have planned a trip on the ride planner APP passing through different cities.
I saved the ride with a name. On both the APP and the PC it shows nice.
When I import the ride into the Boom Box GTS (either via the APP or via the USB pen), instead of saving the single ride with a single name it saves different pieces of the ride making it very difficult to manage.
What am I wrong?
Old Aug 5, 2020 | 03:19 PM
quadmania's Avatar
quadmania
I discovered that if I design a ride without any waypoint in the middle the ride is taken as a single element and integrally loaded into the BOOM GTX. If I introduce some deviations/waypoints in the middle of the created ride the outcome loaded into the BOOM GTS is a sequence of segments, instead of a single ride. How can I avoid this?
Old Aug 5, 2020 | 03:23 PM
rossn2's Avatar
rossn2
Simplest way to explain is there should be only one start and one stop per ride, which is a route. Create everything else along that route as a waypoint and make sure you are zoomed in on the road when you drop the waypoint.
Old Aug 5, 2020 | 03:25 PM
CoolBreeze3646's Avatar
CoolBreeze3646
This may help.
https://www.hdforums.com/forum/road-...nner-help.html
Old Aug 5, 2020 | 03:37 PM
quadmania's Avatar
quadmania
If I do not want to follow the ride designed by the APP because, for instance, I want to follow another path, oblige me to insert some waypoints. Having on the Boom GTS a large number of segments based on the inserted waypoint is confusing a lot because you need to remember the correct sequence and also you neeed to load segment by segment in order to be driven on the way. To me that's very bad!
Old Aug 10, 2020 | 06:42 AM
rossn2's Avatar
rossn2
Maybe carry a printed 8x10 map of your route for the day off Google. Make it wide enough to cover other areas you may want to visit.
Old Aug 16, 2020 | 08:36 PM
LaneG's Avatar
LaneG
Watch these videos. After I did that, no more problems.
https://www.youtube.com/c/EZMotoTim/...y+ride+planner
JohnnyIce
Harley Davidson Videos
Mar 11, 2021 09:29 AM
TravelingTall
Sep 11, 2019 12:08 PM
RidingWithRon
Nov 10, 2016 06:09 PM
frenchy333
May 24, 2015 02:10 AM
JohnnyIce
Road Trips
Jan 3, 2015 09:55 PM
