Harley Ride Planner
Old Jun 5, 2021 | 07:50 PM
Blue Blood's Avatar
Blue Blood
Originally Posted by cycle7447
Are you asking if the Ride Planner runs when using car play? If such is the case, you are correct - seems we can only run one at a time. Even in my vehicles, if I run android auto, I can not run my vehicle internal GPS.
I can however run both google maps and Waze - seems I can toggle between the two.
yeah, and I tried running HD app within CarPlay and it won’t run.
Old Jun 10, 2021 | 03:33 PM
Stick74's Avatar
Stick74
Stage III
Just going to throw this onto this thread, as it seems like an appropriate place, if a bit of a digression. The Issue: The H-D Ride Planner mobile app was not “pulling in” some of the rides I had created and saved in the H-D Ride Planner website (on my laptop). I continued to get a “No Routes Found” response on the mobile app. No (apparent) rhyme or reason for which rides pulled in and which ones didn’t. Finally figured it out, although it may be common knowledge to a lot of you...
It involves the Options setting within the mobile app, or more accurately begins with the AVOID setting in the website Ride Planner. In the website Ride Planner, when creating my ride, I had selected to 'Avoid: Unpaved Roads' on a very few of my created Rides. This setting is pulled over into the mobile app version of Ride Planner, for the given ride. And even though my routing did not include ANY unpaved roads, having the Options setting within the mobile app set to AVOIDANCES: UNPAVED ROADS, always resulted in the "No Routes Found" message every time I tried to invoke the "Ride It" function. I later found by simply de-selecting the Unpaved Roads option from within the app, or permanently de-selecting it from within the website version of Ride Planner (and saving it), the 'Ride It' function within the mobile app immediately pulled in the Routing, and I was able to "Start ->" my ride. Hope you don't mind this add to the thread, and hopefully helps out someone down the line.
So it would seem there is an error in the app programming, in that even though there are no unpaved roads in the planned route, the mobile app version of Ride Planner seems to think there is, and will not pull in the planned route, i.e., "No Routes Found", if the Avoid: Unpaved Roads" option is selected. I use my iPhone for GPS functions, as I ride a 2012 Ultra Ltd, so do not have the Boom Box Infotainment system. I have no idea if this same issue is happening when loading the BBI from either a thumb drive or directly/wirelessly from the iPhone, but if it is, this is the issue and solution.
Old Jun 10, 2021 | 03:52 PM
TexasMotorcycleRider's Avatar
Correction meant to say - There is now an import feature
Yep,I just found that out recently as well. This is great for routes that I created in other programs and want to re-ride or load and edit. Very good addition.
rookie06
Aug 10, 2019 02:03 PM
FXDTim
Harley Davidson Videos
Jun 21, 2019 01:05 PM
jwbenning
Audio Systems
Jun 15, 2019 06:55 AM
Cliffy Amo
Oct 1, 2017 02:10 AM
