Oil Odor
Old Sep 2, 2015 | 07:28 PM
H8HRBT's Avatar
H8HRBT
Default Oil Odor
I've got a 2011 CVO Ultra Glide. it's in excellent condition, runs great, and doesn't leak or burn oil (believe it or not). however, after riding an hour or so, a strong oil smell comes from the engine. I check the oil often and it's still full and clear. the oil and tranny caps are on tight. any ideas?? thanks
Old Sep 2, 2015 | 08:06 PM
Afdharley's Avatar
Afdharley
Most likely coming from the trans vent.
Old Sep 2, 2015 | 08:09 PM
H8HRBT's Avatar
H8HRBT
ok. so, that's normal??
Old Sep 2, 2015 | 11:58 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
It's an internal combustion engine. It has oil in it. It has gasoline in it. It has odors that might be associated with the first two. JFC
Old Sep 3, 2015 | 06:29 AM
H8HRBT's Avatar
H8HRBT
ok, ok, ok....I get it. However, this is my first HD so I'm unfamiliar with 'normal' sounds and smells. All I know is that my Suzuki C50 didn't emit odors and it's also a internal combustion engine. More importantly, my veteran HD fellow riders also think the odor is too strong. just wanting to be sure nothing is wrong. thanks man.
Old Sep 3, 2015 | 07:38 AM
Afdharley's Avatar
Afdharley
Do you know what kind of oil is in the trans? If last owner out gear oil in it, it will smell stronger when it gets hot.
If you can't find any obvious leaks and nothing is dripping on the ground when it's parked then it's probably not a big deal.
Old Sep 3, 2015 | 07:47 AM
H8HRBT's Avatar
H8HRBT
Screaming Eagle Synthetic lube, as per HD specs. maybe is the 'norm' for a 110 since it gets so FRICKIN hot....
Old Sep 3, 2015 | 12:21 PM
Afdharley's Avatar
Afdharley
Yep, they do get hot. I'd say it's probably normal but since the bike is new to you I'd also keep an eye on things for a while.
Old Sep 3, 2015 | 12:24 PM
H8HRBT's Avatar
H8HRBT
certainly will. thank bud
Old Sep 3, 2015 | 04:06 PM
Spindrifter's Avatar
Spindrifter
I noticed this too. It was stronger in the new CVO than my 05 RKC. I however switched to Redline Shockproof in the tranny last oil change and now I don't notice it. Trans vent I my guess too...
