2015 CVO 110 motor work?
Old Nov 13, 2015 | 11:14 AM
VT Hog's Avatar
VT Hog
Default 2015 CVO 110 motor work?
Has anyone done any motor work to there CVO?
Old Nov 13, 2015 | 01:25 PM
GlidingJoe's Avatar
GlidingJoe
Yes I have, and so have several others. My signature shows, but I had Fuel Moto do a little FM magic to my 110.
Installed TW 777 cams, mild port and polished head work resulting in 10.3 compression, 2-1-2 FM header, E Series exhaust, PV-2 tuner which woke it up considerably. Others have done the 113" build by Fuel Moto and have extremely nice results as well.
My numbers are 110 hp and 126 tq. Currently looking for a better breathing AC vs Stock for without it my numbers go to 113 and 129.
I found Little Chute WI. to be pleasant drive and well worth the trip and you wont find a better group of people.
Old Nov 13, 2015 | 01:29 PM
soft 02's Avatar
soft 02
Nope. Your the first one........
Old Nov 13, 2015 | 09:32 PM
VT Hog's Avatar
VT Hog
Did you do the 58mm t-body and injectors?
Old Nov 14, 2015 | 12:02 PM
GlidingJoe's Avatar
GlidingJoe
No, no need to unless you start going to the 113" build.
Old Nov 14, 2015 | 01:51 PM
VT Hog's Avatar
VT Hog
I would think, bigger cams, bigger ports, exhaust and mufflers would justify the 58mm t-body. At least that's what I getting told by the local motor builder here!
Old Nov 14, 2015 | 02:00 PM
GlidingJoe's Avatar
GlidingJoe
Contact Jamie at Fuel Moto and ask him about his builds..
Need Help? Call or Email Us 920-423-3309 info@fuelmotousa.com MON-FRI 9-5PM CST
Old Nov 14, 2015 | 07:26 PM
firefighter156's Avatar
firefighter156
Yup several times. Current one is now a 113" A 58mm may or may not be needed. If you do a new TB I would definitely buy an HPI. The injector size is also important.
Old Nov 24, 2015 | 11:03 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Kury 24D cam is a bell-ringer in a 110".
A Wood 8 works well also.........in our 113"s 130/130 is very common.
The OEM 50mm t/body on those 110" engine has an intake manifold diameter MUCH smaller than the 1.750" port I.D. on the 110" cylinder head casting, and actually pinches the air flow substancially.
An 58mm S&S Throttle Hog is what we reach for with the TBW bikes.
Scott
--JP--
Jun 29, 2016 03:54 PM
hori
Engine Mechanical Topics
Mar 22, 2016 04:22 PM
plongson
2014-2024 Touring Models
17
Jul 5, 2015 07:00 PM
DRAGO'S BIKE WORKS
Blowers/Turbos/Nitrous Oxide
Aug 24, 2012 06:51 PM
Wally
Exhaust System Topics
Sep 16, 2008 06:13 AM
