Cooling System/ECM Failure
Old Dec 24, 2015 | 11:17 AM
BlackMarshmallow's Avatar
BlackMarshmallow
Default Cooling System/ECM Failure
From July 16, 2015 On "another" forum:
Parked this morning and noticed an abnormal sound when I shut down. The radiator fan normally cycles on for a little less than a minute on shut-down and then off. This morning there was an abnormal "non-fan" sound, sort of a loud buzz. I got my flashlight and looked in the radiator shroud and found the fan trying to rotate in 3-5 degree increments. Like either it was jammed or getting a bad control signal. Either way, it looks like a trip by the dealer on the way home today.
Anybody else had this issue?
From today on the "other" forum:
Here we go again:
So it's been 5 months since the Dealer replaced the ECM per corporate directions under warranty. Last week it started throwing codes again. P0691 Fan/Cooling relay output low/open, P0692 Fan/Cooling relay output high, P1691 Cooling fan left low/open, P1692 Cooling fan left shorted high, P1693 Cooling fan right low/open. Yesterday on the way home (37 deg F) it started puking coolant out of the right side lower which it didn't do in July. Looks like another trip to the service bay for the Blackfish.
If it is in fact the ECM going bad, I'm thinking something is taking it out.
What are your thoughts? (This is a 2015 FLTRUSE)
Old Dec 27, 2015 | 10:22 AM
Afdharley's Avatar
Afdharley
Have had the same bike for 1 year now, 13xxx miles. None of the above mentioned issues.
Islandrider1970
Dyna Glide Pictures
Jun 29, 2017 03:20 PM
KaZoo
2014-2024 Touring Models
May 10, 2017 05:19 AM
Cheeto
Oct 11, 2013 12:45 PM
Hock Luger
Apr 23, 2012 03:48 AM
wazapng
Mar 29, 2012 05:54 PM
