At my wits end!
Old Apr 20, 2012 | 04:46 PM
Hock Luger's Avatar
Hock Luger
Default At my wits end!
Hi all
I'm new to this forum and I hope some of you folks don't mind helping an old guy out. I may not be in the right place for this, but I'll try anyway. I recently purchased a 2007 dyna super glide custom that has been basically sitting up for months. The bike has got 16,000 on the clock and ran great when I test drove it and for about 70 enjoyable miles afterward.
Then it started. Was cruising along at about 50 and it backfired loud and died. It didn't want to start back but after sitting for about 30 minutes, it fired up and ran fine for about 2 miles and did it again.
I got it home and the next day the same thing happened. Seems like when it reaches a certain temp. it shuts down, and when it cools, it runs fine.
I found some info online about running diagnostics and did it. I have 4 codes. p0373,p0374,p1353,p1356.
Can somebody tell me what these mean and what I should do? I'm a decent old school wrench, but this is my first efi bike.
Thanks in advance
Hock
Old Apr 20, 2012 | 04:55 PM
SteveO-ll's Avatar
SteveO-ll
Not sure of the codes, I'd have to look them up. Although I would start with the basics of making sure the electrical system is clean and tight at all connections, and double check the crank position sender. I'd also make sure I had good clean fuel in it, after flushing the old stuff out.
That's a start, however I would imagine you've done all that.
Here's the Codes:
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1511 Throttle actuator control power management failure of throttle control actuator
20. P1600 EFI Module Processor Internal Error
21. P1270 TGS Validation Error
22. P2107 EFI Module Processor Internal Fault
23. P2101 throttle actuator control motor circuit range/performace error
24. P2122 TGS1 Low/Open
25. P2123 TGS1 High
26. P2127 TGS2 Low/Open
27. P2128 TGS2 High
28. P2138 TGS Correlation Error (Twist grip sensor)
29. P0120 TPS1 Range Error
30. P0220 TPS2 Range Error
31. P0122 TPS1 Low
32. P0123 TPS2 High/Open
33. P0222 TPS2 Low
34. P0223 TPS2 High/Open
35. P2135 TPS Correlation Error
36. P2119 EFI Motor Throttle Body Range Performance
37. P2100 EFI Motor Circuit Open
38. P2101 EFI Motor Circuit Range Performance (Actuation Error)
39. P2102 EFI Motor Circuit Low
40. P2103 EFI Motor Circuit High
41. P2176 EFI Closed Position Not Learned
42. P1514 Air Flow Fault
43. P2105 EFI Forced engine shutdown
44. P1501 Jiffy Stand Sensor Low
45. P1502 Jiffy Stand Sensor High
46. P0572 Brake Switch Low
47. P0117 ET Sensor Low
48. P0118 ET Sensor High
49. P0112I AT Voltage Low
50. P0113I AT Voltage Open/High
51. P1351 Front Ignition Coil Driver Open/Low
52. P1354 Rear Ignition Coil Driver Open/Low
53. P1352 Front Ignition Coil Driver High/Shorted
54. P1355 Rear Ignition Coil Driver High/Shorted
55. P1357 Front Cylinder Combustion Intermittent
56. P1358 Rear Cylinder Combustion Intermittent
57. P0261 Front Injector Open/Low
58. P0263 Rear Injector Open/Low
59. P0262 Front Injector High
60. P0264 Rear Injector High
61. P0562 Battery Voltage Low
62. P0563 Battery Voltage High
63. P0501 VSS Sensor Low
64. P0502 VSS Sensor High/Open..
65. P1356 Rear Cylinder No Combustion
66. P1353 Front Cylnder No Combustion
67. P0444 Purge Solenoid Open/Low
68. P0445 Purge Solenoid High
69. P1475 Exhaust Actuation Position Error
70. P1477 Exhaust Actuator Open/Low
71. P1478 Exhaust Actuator Shorted/High
72. P0131 Front Oxygen Sensor Low
73. P0151 Rear Oxygen Sensor Low
74. P0132 Front Oxygen Sensor High
75. P0152 Rear Oxygen Sensor High
76. P0134 Front Oxygen Sensor Inactive
77. P0154 Rear Oxygen Sensor Inactive.
78. P1510 EFI Limited Performance Mode
79. P1511 EFI Power Management Mode
80. P1512 EFI Forced Idle Mode
81. P0577 Cruise Control Input High
HFSM = Hands Free Security Module
TSM = Turn signal module
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart
Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High.
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open
B1141(HFSM) Ignition Switch Low/Open
HOPE that HELPS
Old Apr 20, 2012 | 04:56 PM
BeanDyna08's Avatar
BeanDyna08
Default Codes
Here is a link to a post with all the codes. hope it helps.
https://www.hdforums.com/forum/3988078-post4.html
Old Apr 20, 2012 | 04:58 PM
Romeo's Avatar
Romeo
P0373 - CKP (crankshaft position sensor) intermittent
P0374 - CKP sensor synch error
P1353 - Front cylinder no combustion
P1354 - Rear cylinder no combustion.
Check the wires going to the CKP located on the left front end of the crankcase. If the wires look good, remove the CKP and clean the end of it. CKP may be bad though.
Old Apr 20, 2012 | 04:59 PM
user45's Avatar
user45
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Synch Error EFI
P1353 Front Cylinder No Combustion EFI
P1356 Rear Cylinder No Combustion EFI
Source: http://www.gwizit.com/harley/codes.php
Sounds like a faulty Crank Position Sensor
http://harleymanual7.blogspot.com/20...-position.html
Old Apr 20, 2012 | 05:03 PM
SteveO-ll's Avatar
SteveO-ll
LOL..........Now that's what I call quick service to a fella in need.
Old Apr 20, 2012 | 05:05 PM
Romeo's Avatar
Romeo
I forgot to mention that a new CKP Sensor costs about $40.
Hock Luger's Avatar
Hock Luger
I appreciate the input guys. I had a couple of locals tell me it could be bad fuel or maybe the fuel pump, etc. But it starts up and runs great cold. Seems this is only happening when it reached a certain temp. I'm going to check the CKP now.
Old Apr 20, 2012 | 05:07 PM
Hock Luger's Avatar
Hock Luger
Man you cats are great. If I can get going for 40 bucks, I'll buy all the beer!
Old Apr 20, 2012 | 05:14 PM
PoCoBob's Avatar
PoCoBob
I don't know if this would be covered under those codes or not. There has been a number of post where the wires to the fuel injectors had cracked insulation and once the bike warmed up it would start misfiring. If the crank sensor doesn't fix it you might want to look there next.
