Just noticed something
Old Aug 26, 2017 | 05:22 AM
WildX's Avatar
WildX
Default Just noticed something
HD lists the 2017 CVO SG 114 as having 124 FT-LB of Torque and the 2018 with the 117 as the same Torque value. I guess when you remove the Twin cooling you need more CUin to make up the power. Looks like a step backwards.
Old Aug 26, 2017 | 05:31 AM
Ultra61's Avatar
Ultra61
Thats at the crank I believe
Old Aug 26, 2017 | 07:00 AM
Heatwave's Avatar
Heatwave
Member
Around 112ftlbs at the rear wheel. And a lousy 94hp. Pretty weak for a 117. http://www.hotbikeweb.com/2018-harle...lide-dyno-runs
Old Aug 26, 2017 | 10:04 AM
dixonk's Avatar
dixonk
They changed the frames and redesigned the whole line outside of touring. They added a RG to the CVO line this year. I’m sure next year you will see some sort of soft tail in the CVO line.
Old Sep 4, 2017 | 01:47 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
FWIW, my '13 CVO Ultra 110, dyno'ed at 110ft lbs of torque with just a tad over 90 HP. That's with Rinehart XT True Duals and the SE tuner.
I get about 40 MPG (highway miles) at 70 MPH and about 38 MPG between 75-80 MPH.
I've only had the bike to 90MPH twice as I don't care about speed because I know I cannot outrun a crotch rocket. I just want it to run well and cool.
With the cat removed and the Wards Fans installed my bike has never went into the "limp" mode or at other signs of being overheated.
Old Sep 4, 2017 | 03:02 PM
30glock's Avatar
30glock
looks like your happy, why change anything.
Old Sep 4, 2017 | 10:18 PM
cmashark's Avatar
cmashark
Also, look closer at the specs. They dropped the 117 compression ratio to 10.2.
PistolPete83
Screamin Eagle CVO Models
14
May 22, 2020 10:47 PM
Karim Maghrabia
Dec 19, 2018 10:29 AM
MARCUS 79
Aug 26, 2014 09:26 PM
DRAGO'S BIKE WORKS
Blowers/Turbos/Nitrous Oxide
Aug 24, 2012 06:51 PM
mlbraptor
57
Apr 19, 2012 06:59 PM
