2015 CVO Tour Pak Lights
Old Dec 1, 2017 | 12:14 AM
Sunset666's Avatar
Sunset666
Default 2015 CVO Tour Pak Lights
Hi
Have you guys figured how to make the tour pak light work fully for brake?
I have corners: run/turn, and center: run/brake.
I'd like them to work as the limited (or newer CVO)
corners: run/brake/turn
center: run/brake
Is that even possible?
Old Dec 1, 2017 | 07:22 AM
silveradoman2's Avatar
silveradoman2
Check out this thread. Lots of info and there is also a post of another thread with more info. Hopefully this helps.
https://www.hdforums.com/forum/new-r...l#post16870783
Old Dec 1, 2017 | 07:42 AM
glcash's Avatar
glcash
Originally Posted by Sunset666
Hi
center: run/brake
Mines works fully. Brakes light up the whole bar. I didn't do anything special.
Old Dec 1, 2017 | 09:16 AM
Sunset666's Avatar
Sunset666
What year is yours?, judging by the lack of the turn signals bar on the fender it is a newer model where the OEM bar works as that.
Long story short, I have a CVO '18 (HDI), those came without turn signals, bought a light bar from an US CVO (don't know the year thou), but performs as I told. Looking around it is the same behavior of the 2014 CVO, so I figured someone out there didn't like that and found a way to make the whole bar to light on brake.
Old Dec 2, 2017 | 07:41 AM
glcash's Avatar
glcash
Mines is a 2016
Old Dec 2, 2017 | 01:25 PM
Sunset666's Avatar
Sunset666
Default run-turn-brake
I'm pretty sure that was changed on 2016 when they stop shipping CVOs with the fender light bar
glcash
2014-2024 Touring Models
Jun 21, 2019 01:09 PM
dinsmoor17
Screamin Eagle CVO Models
Apr 22, 2016 05:23 PM
p51bombay
Jun 24, 2014 08:36 PM
p51bombay
Jun 8, 2014 07:56 PM
webbug
Aug 4, 2009 11:50 AM
