Dead battery
Old Sep 5, 2018 | 08:15 AM
RichardMebert's Avatar
RichardMebert
Stage IV
Default Dead battery
Does anyone know why the battery always drains in my 2014 CVO breakout ?
The local dealer can’t find the problem... they went so far as to tell me “That’s the way they are ... you have to keep it on a battery tender”
Sorry but I can’t except that I’ve owned plenty of motorcycles, cars , trucks , law movers ... well you get the idea
Old Sep 5, 2018 | 09:43 AM
cbrenthus's Avatar
cbrenthus
How long does it take to drain?
Old Sep 5, 2018 | 10:56 AM
RichardMebert
Stage IV
Not long 3-4 days
Old Sep 5, 2018 | 12:15 PM
cbrenthus's Avatar
cbrenthus
Wow, that's not OK. One thing you could do to try to find it is disconnect the negative terminal, put a meter from the cable to the battery to check current, then start pulling fuses until the current drops.
Old Sep 5, 2018 | 12:17 PM
cbrenthus's Avatar
cbrenthus
Also, how old is the battery? Could be going bad.
Old Sep 5, 2018 | 12:21 PM
Kingglide549's Avatar
Kingglide549
Unplug everything, pull all fuses and breakers.
Now hook up your volt meter to batt.
Plug one thing in at a time until you find the draw.
Now just check the items in that circuit.
yo can do all this in 20 minutes and save thousands $$$$$$$
This is not that difficult.
Always do what you can yourself.
Old Sep 5, 2018 | 12:30 PM
RichardMebert
Stage IV
I was hoping there was a common problem others had
dealer checked it 4 times while still under warranty supposedly installed new battery 2x
now its out and doing it again
its intermittent and only seems to happen a couple of times a year
And no I didn’t leave it on
Old Sep 5, 2018 | 12:47 PM
cbrenthus's Avatar
cbrenthus
Intermittent is going to be a pain to find. No common issue I know of, but maybe someone else will chime in
Old Sep 5, 2018 | 12:48 PM
RichardMebert
Stage IV
Thank you
Old Sep 5, 2018 | 12:54 PM
Kingglide549
I would suspect- regulator IF your battery is good .
