Dead battery
Old Sep 5, 2018 | 06:50 PM
kojak's Avatar
kojak
Originally Posted by RichardMebert
Does anyone know why the battery always drains in my 2014 CVO breakout ?
The local dealer can’t find the problem... they went so far as to tell me “That’s the way they are ... you have to keep it on a battery tender”
Sorry but I can’t except that I’ve owned plenty of motorcycles, cars , trucks , law movers ... well you get the idea
By any chance have you towed the bike before the battery went dead?
Old Sep 6, 2018 | 03:37 AM
gmeikle's Avatar
gmeikle
Here in Australia all new HD's sold since 2006 MUST have factory security system from new. An "Australian design " rule. In the US it is only CVO models that have factory security as stock from new.
As a result of that , the local Perth Western Australia dealer has fitted to ALL new bikes sold a "Battery fighter Junior" brand tender ( We are a 240 Volt country here mind !)
Why ? They were dead sick of replacing batteries "under warranty" as even 4 weeks was proving too much and the dreaded " click clickity click" would occur. MUCHO customer gripes as a result !
I had always fitted tenders of that brand myself since the early 2000's , and have had new batteries last 7 years. Put a new genuine HD battery into my 2008 CVO Springer in 2011 , still good today.
Tender is on soon as the exhaust has cooled enough to allow plug in as the connector is on that side , easier to get to than on the primary side.
Old Sep 7, 2018 | 09:36 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Does this battery discharge if the bike just sits 3-4 days?
Or are you driving it regularly and the battery still discharges?
It would be interesting if you could totally disconnect (or remove) the battery from your bike, make sure that it is fully charged and then let if sit for 3-4 days.
If it retains it's charge, then it would be obvious that the problem is with a "drain" originating from the bike.
If you're riding the bike regularly and the battery continues discharging your could either have that "drain" or it is possible that either your stator is not charging or your voltage regulator isn't working properly.
Usually, the battery is the culprit but since you say that the battery has been replaced twice and the problem still persists, an electrical check of both the voltage regulator and the stator should be your first propriety in diagnosing the problem.
Old Sep 7, 2018 | 09:47 PM
Jonny Rotten's Avatar
Jonny Rotten
Sub'd
Old Sep 14, 2018 | 07:44 AM
nytryder's Avatar
nytryder
When you ride, how long are your trips? It takes 7 miles at 2,000 rpm to recharge one start up. How often do you ride? The newer bikes have systems that continually pull power from the battery 24/7 whether you ride or not. combine that with short trips and you have a problem. A battery tender is your friend. Hope this helps.
JensBobber
General Topics/Tech Tips
Feb 25, 2019 03:18 PM
Wizardofaus
Electrical/Lighting/Alarm
20
Nov 29, 2018 04:03 AM
Mchad
Nov 28, 2018 02:09 PM
Mozvader
May 3, 2018 01:25 PM
MAGNYS
May 20, 2010 05:37 PM
