Negative battery post melt a bit
Old Feb 23, 2019 | 01:10 PM
JensBobber's Avatar
JensBobber
Default Negative battery post melt a bit
I recognized my negative post on the battery was alittle bit melted cause of the heat, but not much. So I took the battery out, cleaned up everything. Now its all good...
Just wondering if this is ok to just put the battery back and ride? The reason for melting was probably cause of the screws wasn't really tight
Old Feb 23, 2019 | 01:22 PM
TwiZted Biker's Avatar
TwiZted Biker
Correct, lose & dirty connects draw heavy amperage and generates a lot of heat. If the battery isn't damaged go for it, dirty lose grounds are a common problem.
Old Feb 23, 2019 | 01:56 PM
JensBobber's Avatar
JensBobber
Thank you for the reply. I don't know if its damaged yet, but hope not. The bike starts and all, guess I have to check after a few miles now
Old Feb 23, 2019 | 02:06 PM
Kingglide549's Avatar
Kingglide549
Make sure you clean the other end of the GRD cable too, and make sure it is tight.
Old Feb 23, 2019 | 02:16 PM
bustert's Avatar
bustert
the post can be repaired fairly easy.
Old Feb 25, 2019 | 01:24 PM
Spartanden's Avatar
Spartanden
how old is the battery? if it is approaching 3 years, I would keep a close eye on it. Would not expect too much more out of it. Keep those nuts and bolts nice and snug. the looseness will create excess heat with will melt the posts. Good on you for catching this. And record this in your notebook!!!
Old Feb 25, 2019 | 03:18 PM
JensBobber's Avatar
JensBobber
The battery is barely 6months old, so I think it will manage
1SikVette
Nov 2, 2018 05:30 PM
hardheaded
Oct 7, 2018 06:41 AM
RichardMebert
Screamin Eagle CVO Models
14
Sep 14, 2018 07:44 AM
Jace Treat
Jun 19, 2018 04:51 PM
donnyj62
Jul 28, 2012 09:14 AM
