I did the Fullsac CVO power cores, didn't care for it at all. Not worth the $, in my opinion.
Bassani DNT slipons sounded much better, even with the stock header.
I have 2018 road glide cvo i did the 2.0 fullsac cores with techmat and did a bassani 2 into 2 head pipe sounds great . I will post video after zippers 468 cam install. Hopefully will be done by next week.
So those of you running them in the 18 CVOs - are you using the $199 OEM kit or the $149 CVO kit?
I also have the Stage 3 kit and went with the high flow exhaust, so the cat is in the muffler not the head pipe. Any idea if the fullsac cores work with mufflers that have the cat in them?
The OEM kit is for non CVO bikes to run the baffles.
The CVO kit is for CVO's.
I am running the CVO kit on both my CVO bikes, with the 2.25 baffle, and the techmat blanket kit.
The best performance is actually the 1.75 baffle, it produces more toque down low, and on a stock bikes doesn't give anything up on the top end.
I prefer the sound of the 2.25, and on my 13 I really need it, as it is a very built motor.
I have a 18 CVO Street glide and I put the 2.25" Fullsac CVO powercores with the tech mat and screens in.
For sure sounds better than stock. I took the factory baffles out and did a couple of short rides while I was waiting for my new baffles to come in. Way to loud without baffles. but I will be getting the Fullsac header over the winter to get a happy medium plus maybe a little more power.
Bill
Bill
Here is what I got with the 2.25 baffles, the Fullsac MX head pipe and a good dyno tune
