Posting here cause i am out of all options as to what it could be...Harley has no idea..... But jumping right to the problem.
If my bike isn't connected to a trickle charger my battery is dead within 3 or 4 days. But also now that even when bike is on the trickle charger it isnt keeping it charged...like the drainage is more powerful than than what the charger is trying to keep up with. I have upgraded my radio but the sound guy has checked and rechecked all possible problems. The radio is completely off and not drawing power at all...My thoughts would be that the alarm on the bike is constant and remains on and slowly draining the battery. Does anyone have this issue or have ran into this issue ? also how would i disconnect the alarm and or turn it off. My audio guy has built thousands of bikes and never had any drained issues with other/older model harleys. It seems to only have this issue if you upgrade audio on cvo models. There is one other guy who went to a different audio guy and having the exact same issue. Anyones thought process on this would be greatly appreciated. Been dealing with this for over a year.
***Also when i replace the battery the bike starts right up like nothing was ever wrong...
I do know that whenever you move this harley or do anything it sounds the alarm and lights blaring... i think that's it possible the current remains constant so that motion of the bike is being detected and slowly killing my battery...what you think ?
Could be the alarm but I'm not sure what the power consumption of the alarm is. Disconnect the positive cable and put a meter between the battery and the cable and verify how many milliamps is being drawn when EVERYTHING is suppose to be off. That is a starting point. Then you might start pulling fuses until the meter shows zero...then you'll know who the thief is...
So for what it's worth, I've not had an issue with my '17 CVO SG. I've had it about 3-4 months and have only had a few times where it went more than a few days without being fired up. I've gone a week without riding with a back injury and still no issues.
I was cautioned by the salesman to always keep it on the charger.
I also carry a jump charger, which will start my bike 23 times if needed.....good for charging cell and gopro as well.
I am kind of in the same boat as you. 15 CVO Limited and I go thru a battery a year. I have replaced 4 brand new batteries so far. Have taken it back to the dealership several times and they can't figure out why the battery drains to the point the bike will not start after it sits for 3 weeks or so. Even as you, when on trickle charge it won't charge the battery enough to start it after 3 weeks of not using it.
New battery and it starts up like its brand new. Something, somewhere has a constant drain on the battery and they can't find it.
Both our CVOs have original trouble free batteries both over 2 years old but I always keep them on the battery tenders with the exception of being on a trip.Our 07 and 08 UCs batteries lasted over 4 years hopefully the new ones do the same.
