I find keeping my hands warm is the only challenge I have in cold weather riding. I used heated gloves, but have ridden comfortably with temps as low as 28°F.
By heating your hands, you heat your whole arms indirectly.
Most the time 2 is the highest I can go on either of my bikes with heated grips. When very cold maybe 3. But they have never been past three, just way to hot for my hands.
I've ridden all day a 20F-24F. 3 is the max I've ever needed. 1 or 2 is my go to for warm comfy hands. So I suppose one of two things, my 2 or 3 is hotter than your grips are at 6, or secondly, your gloves are way thicker and made of asbestos.
6 on mine would probably add significantly to global warming. 4 is near Death Valley mid summer.
I could not hang onto my grips above 4, 5 and 6 are for cooking.
I did enjoy warmer grips with the standard 2016 Limited. I have noticed that the CVO grips are not as warm. I actuall use Rev-It gloves designed specifically for heated grips and have tried others with similiar results. Happy for you guys that get that much heat from them.
When you need them, they are great! When you don't need them and accidentally bump them on somehow, they take awhile to cool down! I wish there was a separately located power switch so that this wasn't an issue.
