Fork lock code
Old Apr 22, 2020 | 04:44 PM
Bikerboot's Avatar
Bikerboot
Stage I
Default Fork lock code
On my 2015 fltruse I’ve gotten a “fork lock” code while riding. The bike shuts down at that point. Some times I can roll on the throttle and it will fire back up. Other times I have to hit the kill switch and turn it back on then start it back up. Has anyone ever had this happen? Remember the fork lock isn’t part of the ignition on the cvo. Thanks for any help.
Old Apr 25, 2020 | 12:41 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Interesting, I have never heard of a fork lock code. Subscribed to see what’s up.
Old Apr 26, 2020 | 09:16 PM
HFS's Avatar
HFS
Just a suggestion: pull over (or just do it in the driveway, be in neutral and rotate fork lock CCW to lock. Does it do it?
Have a friend or whomever to assist and try it while in gear with clutch pulled in...?
For the lock to engage you need to be full lock left but I dunno if I'd wanna try it by switching it while riding.
Did you do any work recently?
Handlebars? Fairing work? Accessories?
I'm guessing but hopefully just a loose wire. Perhaps a disconnect back to ECM. Faulty switch?
Dunno just guessing. 2015 is quite new still.
Good luck
H
JonW
Oct 22, 2019 06:22 PM
hdwd2000
Apr 27, 2016 03:37 PM
Papa G
May 19, 2015 07:58 PM
chorndawg
May 10, 2012 10:08 AM
fryeca
Jul 21, 2006 07:29 PM
