CanBus system
Old Jul 17, 2021 | 02:55 PM
Erzsebet's Avatar
Erzsebet
Default CanBus system
Hi,
I would like to buy a 2012 Softail cvo convertible 110 cubic inch motorbike.
I have a question. Does it have canbus system or not?
What is your opinion about it?
If I want to change the rare light to European version, means have to change 3 in1 indicator is it compicated or not?
Thanks
Old Jul 17, 2021 | 03:06 PM
JustDave13's Avatar
JustDave13
They should.
The canbus is a very efficient way to control many things with only two data lines. This removes tons of wiring from the bike that would otherwise had been needed.
I don't know about the light assembly but I would look at pin layouts and what each pin is for and do a wiring match.
Old Jul 18, 2021 | 04:06 AM
b0fh's Avatar
b0fh
2012 softail has canbus.
which usually gives you lots of headache.
its one of those things that are superior in theory but not in real life.
Old Jul 18, 2021 | 05:33 AM
JustDave13's Avatar
JustDave13
I've very rearly seen problems with it.
Old Jul 19, 2021 | 06:24 AM
GlidingJoe's Avatar
GlidingJoe
Only has problems if you don't understand it and or alter it without doing it properly
Old Jul 19, 2021 | 08:47 AM
b0fh's Avatar
b0fh
or if you wash your bike and don't wrap the handcontrol switches to do so... most common source of heartache around here
theres even ***** specializing on stealing those now - the small PCBs that go in there cost a fortune and failures are abundant (due to washing). they cut the cables, remove the control housings and grips and walk away. 5 minute job.
but agree, if you know what it is and take proper care of it it should work well... i have 2 bikes with the system, one was already pestering me (high beam would engage but not disengage), fixed it by opening that thing and carefully cleaning it (and stoped watering it completely )
had I ignored the issue it would fail and set me back some serious $$$
(yeah i know it costs $150 or so in the USA but reality in Brazil is very different).
Old Jul 19, 2021 | 09:26 AM
Erzsebet's Avatar
Erzsebet
thanks for the answer
e6fmf
General Topics/Tech Tips
May 12, 2019 05:39 AM
JONNIEROCK
Apr 23, 2019 03:35 PM
xupd42bmg
Screamin Eagle CVO Models
Oct 4, 2016 10:34 AM
hotrod351
Engine Mechanical Topics
Sep 28, 2016 08:03 AM
william r
2014-2024 Touring Models
15
Jun 27, 2015 01:23 AM
