Tour Pak Light Trim
Old Jan 28, 2022 | 08:22 PM
Mr D's Avatar
Mr D
Default Tour Pak Light Trim
Is the color matched trim that sits atop the leading edge of the tour pak light a serviceable part ?
I’m wanting to replace the light bar with custom dynamic’s new pro beam tour pak light bar & I want to keep the color matched trim piece if it all possible
Old Jan 29, 2022 | 03:19 AM
smitty901's Avatar
smitty901
I bet CD could answer that Just give them a call Is this the new light you are talking about?
Old Jan 29, 2022 | 07:06 AM
Mr D's Avatar
Mr D
Yes, that’s it
Old Jan 29, 2022 | 11:56 AM
smitty901's Avatar
smitty901
I know nothing of the part you refer to on a CVO. I do know as you can see the light fit where factory one goes .. Should you decide to do it let me know . I learned a few things about using the antenna . Mounts you reuse yours pretty simple once you know how to do it.
2015 Rushmore all tour packs switch to the new one They are different size and shape.
The picture I posted is my 2020 RGL
Old Jan 29, 2022 | 01:24 PM
Mr D's Avatar
Mr D
Here's a chrome one that's avail. in the P&A book...CVO is painted to match from Harley
https://www.harley-davidson.com/us/e...rim/p/53000329
Old Jan 29, 2022 | 01:42 PM
smitty901's Avatar
smitty901
IMO unlikely it will fit the new one is shaped a little different . CD has a Thread here on the sight. Post there they will respond.
Old Jan 29, 2022 | 02:08 PM
Mr D's Avatar
Mr D
Thanks ! are you happy with the result compared to the stock light ?
Old Jan 29, 2022 | 06:02 PM
smitty901's Avatar
smitty901
Yes I am. I had been waiting for this for about a year. We knew it was coming but delays happen .I switch every rear light and front Turn signals to CD pretty much day one. That was the last one I need to change. It goes well with the other CD lights. It is bright.
I am thinning about adding the Flash unit also. I have had it before.
craigffb
2014-2024 Touring Models
Nov 25, 2021 12:41 AM
FLHTKCU
Sep 29, 2018 01:04 PM
PSRumors
Jun 23, 2016 10:47 PM
Rockgeezer
Touring Parts
Jun 9, 2014 12:51 PM
ny2az
Touring Parts
Apr 20, 2011 07:40 PM
