fxdse 110 cam selection
Old Aug 14, 2007 | 10:47 PM
humblepiee30's Avatar
humblepiee30
Default fxdse 110 cam selection
hi,i am looking into changing the cam in my 2007 fxdse 110.the harley dealer where i purchased the bike is recomending the SE 211 cam.has anyone done a cam change with the 110?looking for more power that is streatable.any suggestion would be appreciated.thanks
Old Aug 15, 2007 | 10:28 PM
humblepiee30
Default RE: fxdse 110 cam selection
any comments or opinions?
Old Aug 16, 2007 | 02:34 PM
Blueslover's Avatar
Blueslover
ORIGINAL: humblepiee30
" Bolt in" cam or are you prepared to do extensive headwork, or go to different heads? If you want a bolt in, there are better alternatives, IMO, than anything HD has to offer. If there are warranty issues, and you want to go with HD parts for that reason, need to know what you're after and what you're willing to do to the top end of the engine to get there. Most HD cams need more compression to run.
Old Aug 17, 2007 | 09:00 AM
skyhook's Avatar
skyhook
I agree with blueslover, the best upgrade to do is the heads. I saw a dyno of a 110 with SE251 cams that did pretty well. I think it was over at CVOHARLEY.com. Apparently a big motor like 110 can get away with using a long duration cam with lower compression. The 251 is not a bolt in cam, recommend better valve springs and check valve to piston clearance. The 211 cam is similar to the 251 and might do ok. I'd be interested to see what an andrews 44 would do.
Old Aug 18, 2007 | 12:10 AM
humblepiee30
i really didnt have any plans on doing anything other then bolting in a different cam.i think 110 motors come with 9.3 compression.. se 110 heads are supposed to be a upgrade over stock heads.so i would like to put in a cam that will make more toque and hp over the cam that harley comes with. i believe the cam from se 110 engine is the se 255 cam(fairly small) i feel. what is 44 andrews cams??
Old Aug 18, 2007 | 02:23 PM
skyhook's Avatar
skyhook
andrews 44 is a bolt-in cam that's a little smaller than SE211. The andrews 44 would make torque at lower rpm than the SE211, and probably still pull all the way to redline
Old Aug 18, 2007 | 02:37 PM
humblepiee30
i am not sure the se 211 is too big the the street however we are dealing with the 110".do you have anrews 44 cam specs?
Old Aug 18, 2007 | 04:29 PM
skyhook's Avatar
skyhook
211 is not too big, but it likes around 10.25 or so compression and you only have 9.3. Of course 110" motor will be more forgiving of low compression than a smaller motor would be. Andrews 44 specs:
intake- opens at 21, closes at 41, 242 duration, .495 lift
exhaust- opens at 49, closes at 17, 246 duration, .495 lift
Old Aug 22, 2007 | 04:08 PM
cardboard's Avatar
cardboard
Go to www.latus-hd.com and ask mike what he thinks. I like the andrews cams myself. YOu need to deceide where you want the cams to come in at, meaning the Rpm's. And if yer riding 2 up or what.
Old Sep 12, 2007 | 03:29 PM
cdog's Avatar
cdog
These 110"s aren't known for being the heartiest motor ever made from the get go. I would think that modifying it will cause issues over the long run.
I'm all for mods, but the 110 platform in the CVO's looks a little fragile from the reports.
bedelman10
Engine Mechanical Topics
98
Jul 21, 2016 07:00 PM
HGM
EVO
21
Jan 15, 2010 09:09 PM
Ozoneman
Feb 27, 2009 05:54 PM
rickrides
Exhaust System Topics
May 25, 2008 03:17 AM
cmcsns
Jan 30, 2008 04:06 PM
