1K Service
They serviced my bike up to 30k miles. I do the work now and just changed earl at 35k. Will be doing 40k meself.
Have a buddy who even took his hotrod bike there until it became more than any stage Harley is.
He goes to Ramsey Speed in Phoenix for any performance seeking readers in AZ. Good dude.
But I never encountered any issues during my service period at dealership. Me thinks some just parrot, makes em all bikerish
when doing some negotiating, i worked the first 5 service intervals into the price, no way I would have done that if there wasn't real value there and I knew my fellas would do it right, on my '17 they handled the service for the first 40k miles or so, but eventually i started doing all of the service myself....but even when I was doing most of it myself, I still took it for what I called a 'safety check'....i think a second set of eyes is always a good thing
at one of the safety checks, they were checking out brakes, and felt like one of the front rotors was starting to show signs of overheating, they talked to the service plan provider and got em replaced with my cost being $50....and that included an all new brake pads on the front as well
other than the frame, this is a new bike, i'll let the fellas at the dealership handle it to start....there have already been a couple of updates, and a recall on a brake line fastener.....i don't mind doing the fluids and checking to make sure fasteners are tight....I'll take over most of it after 20k miles....the brakes are easy to do and that is one of the things where I will do it myself....cleaning calipers takes a little more than a few squirts of brake cleaner
With this new ride, I was contemplating to give them a chance and let them do the 1K...
Then their BS started like this
1, After the initial service, oil changes are every 2500 miles ( All Three holes )
2, if you run syn oil you can go a little longer but NO Harley comes with SYN from the factory.
3, HD is just following the automotive industry that is all 2500 mile oil changes.
4, New bike on delivery had a stone dead battery
5, New bike did not have two of the IFCU updates.
6, Out the door I had low tire PSI warning, both were around 5-6 lbs low.
I have zero faith in dealerships!
if my oil story sounds bizarre enough to you as it did me, Ill PM you their phone number if you are curious enough to ask what their recommendations on oil are.
Oil change is 1K, 5K, 10K, 15K, 20K and every 5K after.
