Tour Pack
Old Dec 26, 2008 | 12:43 PM
blackice07's Avatar
blackice07
Question Tour Pack
THis may be a stupid question, but I am starting to look for a SE Ultra. Is the Tourpack on the back removable? If so is it easily removable? WOuld probably remove it for local riding and add a different seat.Then put it back on when on a trip.
Rusty
Old Dec 26, 2008 | 02:52 PM
SteveO's Avatar
SteveO
You could remove it, but the radio amp is mounted under the tour pack, along with the CB wires.
Old Dec 26, 2008 | 05:40 PM
gunner11's Avatar
gunner11
Anything put on can be removed, it's just more complicated. I planned to do that, but after about 2 weeks with it realized I didn't even want to, way too handy!
Old Dec 27, 2008 | 10:45 AM
howtodoit's Avatar
howtodoit
If you want to remove it, just buy a road glide SE
Old Dec 28, 2008 | 07:34 AM
tmason54's Avatar
tmason54
Stage II
Default Tour oack removal
You have to purchase a removable rack and docking hardware about $200. Then after removing the current connetions and bracket from the bike you can then start to remove the tour pack from its existing bracket and replace it on the new rack. Then you will have to remove and replace the parts in the docking hardware, When all of this is finished remember you will need to place a antennae inside of your fairing for your regular radio to work and a separate antennae if you want your cb to work. It isn't hard but it does take time. The other problem is where to coil the wiring when you don't have your tourpak on.
bloozeman2002
May 19, 2012 07:26 AM
easyryder01
Aug 15, 2011 01:44 PM
alandchris
Feb 7, 2009 07:47 AM
dobber709
Oct 23, 2007 01:34 AM
kevdog
Jun 30, 2006 12:06 AM
