Big exhaust problem
Old Aug 28, 2010 | 06:48 PM
harleybob's Avatar
harleybob
Default Big exhaust problem
Today I put the vance and hines power dual head pipes on and monster round mufflers. I have exhaust leaks at both jugs.I bought the screaming eagle gaskets. But they looked thinner so I used the gaskets that came with the head pipes. And yes I torqued ever thing . All help greatly appreciated.This is a 2010 se ultra. Thanks Bob.
Old Aug 29, 2010 | 06:06 AM
wheelsnkeels's Avatar
wheelsnkeels
Reinstall using the Screamin Eagle gasket even though they appear smaller they seal better.
I had an issue with mine where the exhaust nuts actually fell off and had similar issues to yours when I tried the original style soft tapered gaskets. After removing and reinstalling with the Screamin Eagle non compressible gaskets no problems.
This time I also added stainless lock washers and nuts
Old Aug 29, 2010 | 11:30 AM
SEEGER's Avatar
SEEGER
Agree.......had the same issues and put on the SE gaskets, problem solved
Old Aug 29, 2010 | 06:08 PM
harleybob's Avatar
harleybob
Problem solved.I went over to a Harley dealer Sunday Morning. Talk to a mechanic. He says you know what I do with the Vance and hines gaskets. I throw them in the garbage. I
He says I dont use se gaskets either.Use the crush type he says that came with the bike. I did problem solved and a lesson learned. It was like putting on two sets of pipes this weekend. Oh they do sound good nice deep rumble at an idle. Thanks for the replies. Bob.
Old Aug 31, 2010 | 01:37 PM
dave29's Avatar
dave29
6th Gear
I just did three SE bikes in the past three weeks. Used the stock HD crushable exhaust gaskets and i'm batting a 1000!! No problems.
Old Aug 31, 2010 | 03:11 PM
Mr. Wizard's Avatar
Mr. Wizard
Just watch the crush type gaskets as they can close up your exhaust ports by making them smaller when they crush. Don't over tighten them. The SE gaskets will not do this neither will Jim's gaskets.
jude0808
Exhaust System Topics
Apr 13, 2016 06:31 PM
broeli
Sep 27, 2011 07:01 PM
jm04
May 31, 2011 03:09 AM
kjr2492
Apr 2, 2011 10:59 PM
lhcstreetbob
Aug 12, 2010 06:44 AM
