Comments on Build
Old Feb 7, 2011 | 11:07 AM
JKM's Avatar
JKM
Default Comments on Build
Looking at a used 2008 SERK (110") with the following build
bub true duals pipe (Tru-dual7)
screamin eagle hi-flo air intake
HD Race Tuner
58mm throttle body
HD hi-flo injectors
Dyno tuned at the dealer
Any thoughts on this set-up?
Old Feb 14, 2011 | 11:02 AM
jad's Avatar
jad
Not sure you need the 58 mm throttle body and high flow injectors without doing cams and head porting to match.
I just went through a steep learning curve by doing a similar build on my bike. With stock heads, compression and cams the 58 mm throttle body isn’t helping much.
Should you want to do all the other work then I could see using it.
One other note, the 58 mm throttle body is kind of a bastard. The only true 58 mm air cleaner is the Harley one. Should you want an after market you would need to modify it.
Pop-pop2
Engine Mechanical Topics
Jan 12, 2019 07:39 PM
Nostradamus74
Feb 24, 2016 02:29 PM
BOSOXFan
Aug 25, 2015 04:48 PM
slyedog
20
Oct 20, 2014 11:01 AM
ACRblaze
Jun 19, 2012 01:31 PM
