cvo mpg
Old Aug 10, 2007 | 10:25 PM
keving73's Avatar
keving73
Default RE: cvo mpg
The gas light doesn't come on till around 160-170 miles, I have gotten 180 before fill up but it was running it close to dry. I was told once the light comes on, you have about 20 miles and I've pushed that.
[IMG]local://upfiles/38401/F05BF3D7CA7E4C7B9D4EAFF671DA3E44.jpg[/IMG]
Old Aug 15, 2007 | 05:42 PM
Blueslover's Avatar
Blueslover
Default RE: cvo mpg
ORIGINAL: rmarion
ORIGINAL: keving73
I normally get 180 miles before I really need to fill up on an 02 SE roadking, I ride to work alot on the highway with the cruise set at 90mph usually at 5am.
[IMG]local://upfiles/38401/F7BB9A9B36CA415691C9674C845383E8.jpg[/IMG]
whats up with those RK?????????
my buds rides a 07 Custom and fills up aroun 190-200 miles?????? I'm lucky to get around 150 mi???
02 is a 95" motor.
If you get 40, be happy. If you run hard, expect 32-35. IF it's tuned, that is. Completely stock will see 40 a lot.
Old Aug 22, 2007 | 04:15 PM
cardboard's Avatar
cardboard
Default RE: cvo mpg
Man Please ! you guys are makin me feel good. I not in the SE club. I got a 103 Indy build and I'm still gettin 54mpg on my ride and I got about the hp and tq as the 110 motor. My bike was dynoed before I gave it time to auto tune itself too. Its SAE measurements too.
Old Aug 22, 2007 | 08:53 PM
neabud's Avatar
neabud
Default RE: cvo mpg
Been giving some thought to buyingthe 08SEUC..I like the 110. Butreading this thread about the mileage ads a twist to it when comparing the HD propaganda.
Looking at the HD specs online they make the following claims: 07 UCEG 45 hwy 32 cty
08 "54 35
08 SEUC5336
Does the 06 SEUC 103 getany better mileage?
I've got an 06RK w/ SE 65115-98B s/o, Stg 1, 25deg TBs.
I've alsogiving lots of thought to keeping the 06 for a couple more yearsand just do the StageII with the SE203 cams for now, butmany caution me that it will make a big impact on mpg. On the hwy I cruise at about 72 most of the time and currently get about 45mpg when 2up. IfI crank it up to 80, mileage drops to about 36-34mpg.
You have some nice bikesgang. Thanks
Old Aug 23, 2007 | 03:43 PM
Blueslover's Avatar
Blueslover
Default RE: cvo mpg
ORIGINAL: neabud
08 "54 35
08 SEUC5336
If you putt around, never letting the bike get over 2500rpm, you MIGHT, on a perfect day, see 50mpg.
Those who have the SEUC with a 110...if you are running pipes and a SERT/PCIII and not breaking 100TQ, you got a chitty tune. Also, the Ultra does NOT come with an SE air cleaner, even if your dealer/salesman said it did...he either doesn't know better, or he/she is lying. If you put pipes on, do the backplate with K&N filter, and get a good tune with either a SERT or PCIII, you should see numbers from 105 to 110 easily for TQ. The 110 does not put out the HP numbers of the 103, but is a bit better on the TQ side. 110 HP will be down in the low 90's or high 80's, depending on the pipe.
If you ride these bikes, expect fuel mileage in the 32-40 range, depending on how fast you ride. The head design on the 103/110 Screaming Eagle CVO motors is extremely inefficient in it's design. The only way to fix that is to get new heads or have the stock heads reworked.
Old Aug 30, 2007 | 12:29 PM
madurodave's Avatar
madurodave
Default RE: cvo mpg
ORIGINAL: Blueslover
ORIGINAL: WPB_07FXDSE
My '07 FXDSE just received a new set of Vance & Hines Big Radius pipes and a SERT and 5 hours on the dyno now giving me 96 HP and 144 ft. lb. of torque to the rear wheel. That's the good news......... :-)
The bad news is that she's a gas hog now ! But alas, that my friends is the price we pay for bat-outta-hell performance cause she absolutely flies !!!
144TQ?!!!!!! That's either a typo or a happy dyno. 114TQ would be more like it.
Whew! I was getting mad at my dealer. I only have 99 hp with 115 tq.
Old Sep 3, 2007 | 10:08 AM
Purple Thunder's Avatar
Purple Thunder
Default RE: cvo mpg
apparently the 02's have the iceing and the cake. 95" motor and the best gas mailage of the CVO's. I get between 42 and 47, Don't run hard but most of my driving is in the Smokies. LOTS OF PULLING,
Remap, Rolled Thunder pipes and Hi Flow Air Filter. Pretty much stock 59,000 miles
Afishinado
Milwaukee Eight (M8)
Jul 17, 2021 08:50 AM
TriGeezer
20
Jun 11, 2017 11:51 PM
Allen_lemessurier@yahoo.com
May 9, 2017 09:23 AM
Ohio HD Guy
Audio Systems
Oct 25, 2015 07:39 AM
Bushy
Aug 29, 2013 08:36 PM
