Swing arm bearing assembly
Old Dec 29, 2014 | 07:39 PM
cajun1957a's Avatar
cajun1957a
no the 900 is not stock and john yes it was a dumb mistake one i wont make again i did have a manual and in almost every single time i referred to it. sporty swingarms are a tad different but not that much of a difference but something i totally missed. thanks for the help
randy
Old Dec 30, 2014 | 09:31 AM
Racepres's Avatar
Racepres
And, I find the two very different in the way the preload is set, pushing the Race instead of the "cone" was a concept I had to get straight ...Long ago luckily!
Old Dec 31, 2014 | 09:19 AM
pjb's Avatar
pjb
I'm sure you "pros" know this, but for the rest:
When I recently replaced swing arm bearings in my 76 FLH I found that the pivot bolt was stripped out where it goes into the frame, and wouldn't tighten enough. I was pleasantly surprised to find they make an over-sized, self-tapping pivot bolt for this exact problem. It worked perfectly, and was an easy fix.
Old Dec 31, 2014 | 10:21 AM
Racepres's Avatar
Racepres
Good and Valid...Many have been used thru the years.
One of the Better Ideas!
Old Dec 31, 2014 | 10:56 AM
johnjzjz's Avatar
johnjzjz
and it come in 3 over sizes .025 .050 and i believe .070 larger < never used that one as i believe on some it interferes with the bearings being able to slide on we just welded the hole and re tapped it stock thread -- good point but he is not at that point yet
Old Jan 1, 2015 | 01:20 PM
cajun1957a's Avatar
cajun1957a
I got lucky when I reassembled everything. All is tight and snug.
randy
Old Jan 1, 2015 | 08:09 PM
johnjzjz's Avatar
johnjzjz
good for you
panz4ever
Shovelhead
Jul 27, 2019 03:37 PM
g1625s
EVO
28
Feb 21, 2019 10:14 AM
JakeUSAF
2014-2024 Touring Models
Oct 9, 2017 11:03 AM
El Chiguete
General Topics/Tech Tips
Aug 4, 2015 09:53 AM
RidemyEVO
Apr 18, 2015 07:53 PM
