I'm still thinking an extra washer may have gotten installed behind the rotor, you need that lip on the front or that thin lipped inside belt guide gets crushed outa shape.
I never used the inside belt guide,the rotor works fine...loosing that "made-on" washer will move it exactly 1/4"
I did use the inner belt guide which is usually flat and 16 gauge, not really enough to make that much of a difference. To set the Rotor i usually use a vernier caliper to measure how far the stator sticks out then add a .020" shim..
Tom, where did you get the idler bearing for the belt... I could use one of them...
