Riding along when motor seized!!!
Old Mar 23, 2017 | 04:10 PM
  #111
johnjzjz's Avatar
johnjzjz
Originally Posted by unluckyluke
Could this be the culprit?
LOOKING AT THE TOP OF CASE WHERE FRONT JUG MOUNTS TO AND SEEN THAT THE OIL DRAININGE PASSAGE IS BLOCKED BY THE GASKET!!! What can this cause?
http://www.flickr.com/photos/1526829.../shares/96512d
Also what brand cylinder heads are these?
http://www.flickr.com/photos/1526829.../shares/67qk85
the heads are early the center fins are tall - the 4 and 5 on the two heads is the casting month year follows -
the gasket indent is a carry over from the internal oiling engines 1948 to 1954 - that oiled the top end through the jugs into the early panheads
later blocks still used the passage in the front head location so they could drill the oil passage for hyd lifters that came after -- the oiling systems in the early engines was always under some sort of up dates, as the oil itself was changing and so was the power out put
Old Mar 23, 2017 | 05:00 PM
  #112
TwiZted Biker's Avatar
TwiZted Biker
Heads look stock, somebody dual plugged them.
Old Mar 28, 2017 | 11:42 PM
  #113
aquadave's Avatar
aquadave
did it drop a valve? those pushrods look like hell
Old Jul 30, 2017 | 02:07 PM
  #114
berndog's Avatar
berndog
Been awhile since i've been on here,thuis thread is very interesting ,been 2 years since my 82 shovel seized on me,discovered oil sender was cracked so not all oil was being pumped up to heads ,Ive yet ti tear it down,kicking myself,i love that bike rebuilt motor and tranny and learned most of what i know right here,a lot from TwiZted Biker,Thank you very much btw,so i really hope for you this has a positive outcome,as Shovels rule!!! I bougfht a new Road Glide,havent wrenched in 2 years its comfy, but missing 2 main things,The character of a shovel is by far no comparison,and the experience,even my lady misses that ole girl that would break down on side of road. Best part,i always knew how to fix it when I got home.look forward to seeing how this turns out,and i'll let ya know how mine is coming.
Old Jul 30, 2017 | 05:27 PM
  #115
carlgrover's Avatar
carlgrover
Considering the last active post on this thread was in March, I don't think it worked out too good for the OP.
carl
Old Aug 9, 2017 | 10:52 AM
  #116
unluckyluke's Avatar
unluckyluke
Not much to say engine needs a rebuild! Rod was bent due to crankshaft falling apart on the inside of the motor
TroubledWine
Engine Mechanical Topics
May 9, 2018 04:26 PM
mayhem912
Nov 17, 2017 08:39 AM
jrscars
Exhaust System Topics
Nov 20, 2012 01:51 PM
Tired_bird
Sep 17, 2010 01:26 AM
Z
Sep 13, 2006 12:34 PM
