Starter gear/bendix removal procedure
Old Dec 30, 2018 | 07:39 AM
Racepres's Avatar
Racepres
Some good advise flowing.. i'll let that go... but, Do Not put another Chiwanese Bendix in there unless you really Like this Job!!!!
Old Dec 30, 2018 | 08:22 AM
johnjzjz's Avatar
johnjzjz
Originally Posted by x392
How did you prevent the starter shaft from turning so you can unscrew the nut (left hand thread) in the end of the starter shaft? this nut holds the Bendix gear on. On my 1984 shovel there is a nut there. I am also trying to avoid removing the battery and starter etc.
with that idea you have - you may need to make a trip to have some fingers put back on
Old Dec 30, 2018 | 08:34 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by racepres
some good advise flowing.. I'll let that go... But, do not put another chiwanese bendix in there unless you really like this job!!!!
b i n g o !!!
Old Dec 31, 2018 | 03:51 AM
d_slat's Avatar
d_slat
Do NOT try this without disconnecting the battery! Pulling out on the bendix will complete the starter circuit, and it will spin. Your fingers would likely not survive this event.
Old Dec 31, 2018 | 08:10 AM
x392's Avatar
x392
6th Gear
yes, i know. the battery will be disconnected. the question is, how do i keep the shaft from turning so i can remove the nut?
Old Dec 31, 2018 | 08:11 AM
x392's Avatar
x392
6th Gear
yes, i know. the battery will be disconnected. but my the question is, how do i keep the shaft from turning so i can remove the nut?
Old Dec 31, 2018 | 08:13 AM
x392's Avatar
x392
6th Gear
yeah local HD dealer has a OEM part on order for me.
Old Dec 31, 2018 | 08:20 AM
johnjzjz's Avatar
johnjzjz
the dealer part will be a china piece - everything from them is china today as an after sell at USA pricing of course
check the bag what does it say made in ???
the starter shaft will need to be put in alloy vise jaws and the nut is reverse thread 5/8 wrench and snap ring plyers also needed
Rusty Axle
Shovelhead
Nov 4, 2017 01:39 PM
Mwh1983
15
Apr 3, 2017 10:48 PM
FL-kruzen
Nov 1, 2013 04:35 PM
jason8251
Electrical/Lighting/Alarm
Jul 27, 2011 03:23 PM
galtjunk
EVO
21
Dec 5, 2009 08:20 AM
