4 speed issues
Old Nov 26, 2017 | 12:44 PM
Matthew Peoples's Avatar
Matthew Peoples
Default 4 speed issues
I have just fixed the transmission because it was leaking. changed main shaft, main bearings seals/gaskets and clutch now the bike will ride for a while and then the clutch cable slips loose and I have to re adjust my clutch in the primary. what would cause this to keep slipping loose? It has happen twice in about 30 miles. Should i use a secondary bolt to lock the adjusting screw and bolt?
Old Nov 26, 2017 | 03:26 PM
johnjzjz's Avatar
johnjzjz
your TOB throw out bearing has an issue - its on the other end of what your adjusting pull the kicker cover off and see whats up
Old Nov 26, 2017 | 03:45 PM
TwiZted Biker's Avatar
TwiZted Biker
It's the throw out bearing or the adjusting stud in the pressure plate eating itself.
Old Nov 26, 2017 | 03:55 PM
Matthew Peoples
Well it happend yesterday I assumed it was the adjusting screw slipped loos again but when I opened it up it was still in place. My cable is bad. Should of just replaced it anyways when putting it all back in. I'll get around to ordering some more stuff soon. should be ready for next season.
jayhawkclint
Apr 1, 2016 06:41 PM
SeaZund
Shovelhead
24
Mar 5, 2015 07:58 AM
BigCaveman
Oct 19, 2012 06:07 AM
jeffwest5599
Shovelhead
Nov 22, 2010 07:00 PM
shovel pat
Shovelhead
Oct 30, 2008 05:07 PM
