Lifter ?
Old Dec 16, 2017 | 08:38 AM
NELS's Avatar
NELS
Default Lifter ?
1971 FLH
Is there a way to determine if a lifter is hydraulic or solid by looking at it?
I'm having trouble getting the lifter block off.
Old Dec 16, 2017 | 09:59 AM
panz4ever's Avatar
panz4ever
That is a hydraulic lifter. Make sure and keep the lifter and tappet together and don't mix them.
Lifter block won't come off? When was the last time the motor was taken apart? The lifter block has a gasket under it. The gasket is probably what is keep the block from coming off. If it has been on there a while, the gasket sealer used has hardened. Try a thin putty knife between the block and engine case. Just don't gough it.
Old Dec 16, 2017 | 10:23 AM
NELS's Avatar
NELS
Bike had about 10k on it but the front head was changed and a heli- coil installed in the plug hole. Bike was abused by po he was a great welder but strong armed when it came to the bike.
I'm soaking the lifter block gasket and using a brass drift to tap it . Being careful , time will work.
Thanks for the reply.
Old Dec 16, 2017 | 09:10 PM
johnjzjz's Avatar
johnjzjz
we use a big plastic hammer and give it a good whack
Old Dec 17, 2017 | 10:15 PM
TwiZted Biker's Avatar
TwiZted Biker
What John said, some of the old big thick gaskets sometimes don't like to let go without a bit of persuasion.
Old Dec 24, 2017 | 04:11 AM
Hoginedgewood's Avatar
Hoginedgewood
I thought that was a tappet.
Old Dec 24, 2017 | 01:48 PM
TwiZted Biker
Lifter is the insert that goes inside the tappet which rides on the cam, google tappet it'll explain.
Old Dec 25, 2017 | 02:43 AM
NELS's Avatar
NELS
Reason I asked was one of the pushrods was adjusted all the way out and I didn't have to touch the adjustment to remove it. Filled it it on the bench and blocked the hole and wasn't able to depress it until I removed my finger. I know the valve spring is much tougher than my finger but the lifter seemed to hold pressure ok. Maybe dirt was blocking the oil passage and it was adjusted like a solid? .I'm able to buy a single lifter if needed. lobes and lifters don't show any wear.
Old Dec 25, 2017 | 06:44 AM
johnjzjz's Avatar
johnjzjz
its looseness of the roller that is the issue - can you feel any in and out when pulling / pushing on the tappets roller / after washing it totally clean and dry
as a side note the roller wheel sides become scratched when the lifter roller is at time to replace, even when it has no play its turning enough to hit the lifter sides, this is showing needle bearing and or pin wear
Old Dec 25, 2017 | 07:09 AM
NELS's Avatar
NELS
Thanks for the info ( again ) I'll check for that wear later.
2ndgenmarine
Mar 27, 2020 04:09 AM
brad75raiders
EVO
Jan 12, 2017 12:40 PM
kishstl
Mar 30, 2014 04:11 PM
Mountain Child
Exhaust System Topics
May 6, 2013 10:04 AM
afiend59
Oil Archive (no new posts)
May 25, 2008 11:24 AM
