Starter question
Old Dec 19, 2017 | 05:33 PM
FL54's Avatar
FL54
That's right Twisted. I feel the same about my Road Glide. These bikes are too heavy to compression start unless you have a convenient hill. Or maybe we're just getting weaker in our old age.
Old Dec 19, 2017 | 07:22 PM
TwiZted Biker's Avatar
TwiZted Biker
Not really the new bike's are just a crap load heavier, RK's 835 on the kickstand, makes the shovel feel like a dirt bike when I get on her
Old Dec 19, 2017 | 08:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yea, might not be as light as a Sporty but at 600b it is a nimble ride...
Old Dec 19, 2017 | 08:05 PM
LilRosie's Avatar
LilRosie
Have you recently tuned up the motor on your 67 ? If so, you might wanna check the timing again, or try advancing the timing a few degrees.
Old Dec 20, 2017 | 08:12 AM
FL54's Avatar
FL54
I tuned the bike a few months ago Lil Rosie. She really has never run better. Except for this occasional starter spin. If the starter engages properly, she fires up immediately.
Old Dec 20, 2017 | 04:07 PM
johnjzjz's Avatar
johnjzjz
the all ***** gear seems to be the end all of starter Bendix drives - but they don't give them away
Old Dec 20, 2017 | 05:38 PM
LilRosie's Avatar
LilRosie
Did you have the starter problem before you tuned up your bike? If not, advancing your timing a few degrees will be the easiest to trouble shoot your problem. Especially if your 67 has the original outer primary cover and dual exhaust.
Old Dec 21, 2017 | 08:24 AM
FL54's Avatar
FL54
I could try advancing the timing a degree or two but the problem is winter is upon us and I won't be able to ride until we get a window of warmer weather. Also, this is just an occasional occurrence. The bike has an aftermarket outer primary courtesy of the PO that has a derby cover so I may be able to change out the Bendix without taking the exhaust and outer primary off. Thanks for the input.
Old Dec 21, 2017 | 08:48 AM
98hotrodfatboy
Advancing the timing will not help, if anything could slow the cranking rpm once the starter engages....
Old Dec 21, 2017 | 03:06 PM
johnjzjz's Avatar
johnjzjz
from the right side - battery and covers the starter then the starter housing bolted to the inner - left side the outer primary then pull the solenoid then the clutch hub and shell - then the gear and shaft come out = we do it this way as we can grease up all the returning pieces as doing it that way is spins faster and lasts longer
