Starter question
Old Dec 25, 2017 | 05:16 PM
  #31
johnjzjz's Avatar
johnjzjz
we have machine tooling in the shop and no spec was ever given so I set them at .015 and call it a day like a camshaft - but I also made a tool that lets me feeler gauge it
Old Dec 25, 2017 | 05:54 PM
  #32
FL54's Avatar
FL54
Thanks for interrupting your Christmas John. But at the risk of sounding thick, how do you set it?
Old Dec 25, 2017 | 07:44 PM
  #33
johnjzjz's Avatar
johnjzjz
I can send you the cut off cover in the mail - you then shim it and use a feeler gauge
send me a PM I can put it in the mail
Old Dec 26, 2017 | 08:16 PM
  #34
LilRosie's Avatar
LilRosie
Keep in mind when using a 1970 and later primary cover on a 1967, the hole w/the needle bearings that supports the starter shaft are recessed approx. 1/2" in from the gasket surface then the one on a 1966 to 1969 primary cover, which the hole w/the needle bearings that supports the starter shaft are flush w/the gasket surface.
Old Dec 27, 2017 | 09:22 AM
  #35
FL54's Avatar
FL54
Thanks LilRosie. Not sure what kind of outer primary I have other than it's not stock. Chrome with derby cover not aluminum without one. That may explain why the thrust washer can move around? What if anything to do?
Thanks.
Old Dec 27, 2017 | 11:57 AM
  #36
FL54's Avatar
FL54
Even though I know LilRosie knows of what he speaks , I confirmed that bearing in the primary is recessed compared to the OEM outer primary. Could extra thrust washers be added? Picture of replaced Bendix and one that was replaced.
Attached Thumbnails Starter question-img_1081.jpg   Starter question-img_1082.jpg
Old Dec 27, 2017 | 04:18 PM
  #37
johnjzjz's Avatar
johnjzjz
the travel of the gear was to great and that is why its chewed
the blind way would be to keep putting washers on with out a primary gasket till the primary sticks out, then we would machine something to get that distance the thickness if the gasket as your end play
Old Dec 27, 2017 | 05:02 PM
  #38
FL54's Avatar
FL54
Roger that John. I ordered 3 thrust washers, I have the original and I may have another in my parts stash. I'll check when the washers come in.
Thanks again.
Old Dec 27, 2017 | 08:17 PM
  #39
johnjzjz's Avatar
johnjzjz
if you were not in a hurry to finish it I believe they make a conversion end piece that fixes the issue ( forgot about that little thing till just now and I might have one will look in the morning )
Old Dec 27, 2017 | 11:06 PM
  #40
FL54's Avatar
FL54
Not in a hurry as it's cold here as I'm sure it is in Jersey and I'm waiting on the thrust washers. It doesn't matter now as I've got all winter to make it right.
Thanks for all your help.
