‘76 FLH Won’t Idle
Old Feb 12, 2018 | 04:01 PM
USKEW's Avatar
USKEW
5th Gear
Default ‘76 FLH Won’t Idle
im trying to help my father get his Liberty Edition back on the road. Got the carb back from the dealer, rebuilt. Put it on, cranked, idled for a minute...now won’t even crank. Let it sit for a while, it’ll crank and idle for 10 seconds at 1/2 choke....then nothing again. Suggestions please. Thanks
Old Feb 12, 2018 | 04:49 PM
carlgrover's Avatar
carlgrover
The intake is probably leaking air. Could be at the jugs, maybe between the carb and intake.
Take the carb off and check to see if there are any bad gaps inbetween the intake and the jugs. You do this by looking down the inside of the intake with a little inspection mirror and a flashlight. The crack inbetween the intake and jugs should be uniform all the way around.
Now make a plate to cover the intake. Put a shraeder valve in the center of the plate. Put an air hose on there (use the kind truckers use that you don't have to hold) with about 10 psi on it. Spray the intake at the seals and look for bubbles. You may have to jockey the intake around and adjust the band clamp tightness to get it leak free. That could take a few tries. Once it's leak free put the carb on and use some gasket maker in addition to the gasket that goes inbetween the carb and intake. That has to cure for 24 hrs minimum before you start the bike.
You must use a bracket to hold up the carb/air cleaner assembly or it will still leak. Do whatever you have to to make sure the bracket holds everything up in just exactly the position you have it in now.
carl
Old Feb 12, 2018 | 05:46 PM
USKEW's Avatar
USKEW
5th Gear
carl
Thanks. When I put the carb on...the bands at the cylinders were loose on one side...I tightened, but there may still be a leak there.
Old Feb 13, 2018 | 11:58 AM
panz4ever's Avatar
panz4ever
Did you replace the rubber O-rings? Old rubber will never seal because it is too hard.
How long has the bike been sitting? Are the inside of the tanks clean? Did you pull the fuel valve and make sure the filter is clean?
Old Feb 13, 2018 | 01:12 PM
USKEW's Avatar
USKEW
5th Gear
Y’all want to know what else works? Put gas in the tank. 😳🙄
Old Feb 14, 2018 | 09:47 AM
V_twins's Avatar
V_twins
HA HA!!!
Yep.. that helps!
Paulzaplitny
EVO
21
May 19, 2016 06:27 PM
hunter20
May 15, 2016 03:47 AM
cuyahoga
EVO
Oct 24, 2014 10:51 PM
95yj
EVO
Sep 5, 2011 09:52 PM
sheem2153
Exhaust System Topics
May 13, 2010 10:16 AM
