String Damper?
Old Mar 3, 2018 | 08:49 PM
Racepres's Avatar
Racepres
Ok so maybe I was wrong about the fl's, that are 41mm excuse me.... but all the old Sportsters and fx's were 35 and the FL's had a better ride so obviously was switched I only said Wide Glide because now, it kind of makes it look like a wide glide as this style wide front end on an fx Style chassis..
I do Not remember any ride Difference... FX vs FL... The FL may steer a bit Heavy/Slow, but I much prefer the FX for My particular Riding Style..
I am Having a very hard time surmising what you have there.
Was it me... I would obtain a Stock tree and front end set-up, unless you have access to a Full 39mm [Dyna Type] front end. Said to be superior... But, I have rode both, and I do Not find a Measurable Difference.
The "Wide Glide" on the other hand... feels Heavy and Slow to me... They generally Look Cool Tho...
YMMV
Old Mar 3, 2018 | 09:37 PM
johnjzjz's Avatar
johnjzjz
bob just take pictures of what you have in its entirety when / and as you take it apart to re grease the neck bearings you talked about - with the pictures it will re assemble the same way, as it is now as I do not believe you will find what you have in any book
Old Mar 4, 2018 | 08:04 AM
Racepres's Avatar
Racepres
I agree... If it was assembled Correctly the First Time!!!
Old Mar 4, 2018 | 07:13 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Will do.. Thanks John...
VoiceofReason44
Jul 13, 2017 06:59 AM
jag1886
Feb 14, 2012 04:51 PM
nkauf21
Jan 28, 2012 04:53 PM
10Seconds
EVO
May 2, 2011 05:29 AM
mrthinkshesfunny
Apr 17, 2008 01:30 PM
