Starter not working
Old Jun 12, 2018 | 02:57 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by 55 Pan
you cant test the starter and bendix with the primary cover off.. what he said above.
Old Jun 12, 2018 | 10:16 PM
Bill wallace's Avatar
Bill wallace
Sleighcrane...that makes sense.
Old Jun 12, 2018 | 10:24 PM
Bill wallace
So here’s my theory after checking every other possible thing that could be wrong. I put new brushes in the starter but I only changed the brushes that were attached to the terminal that sticks out the side of the starter the cable is attached to. I did not change the field coil brushes. This may result in a starter that is just not putting out enough power, Because the Bendix gear will spin, but as soon as it hits the ring on the outside of the clutch shell, it stops. So that tells me power from the starter is being transferred from the starter, through the gear case and up to the shaft and finally the pinion/bendix gear. But I think it just does not have enough power to turn the motor. So the only thing I can think of is replacing the field coil brushes. I will give that a shot when I get around to it and let you guys know how turns out. Sure has been interesting
Old Jun 13, 2018 | 07:10 AM
Jackie Paper's Avatar
Jackie Paper
Make sure the insulator between the fields on the communtator has a recess. Sould be at a minimum, a 1/64 below top. The brass on a starter could easily be worn below. (Use a extra fine short piece of hacksaw blade to carefully lower insulator)
If this is not done, the brushes are held off the communtator a little more then a brush width greatly reducing motor power besides bouncing the brushes causing a fireball of arching.
Old Jun 13, 2018 | 10:04 AM
Bill wallace
When I kick start it, the clutch basket travels ccw (counter-clockwise). Ok, so the bendix gear free spins cw and locks ccw. In looking at this with the primary off, I would have to say that In order for the bendix gear to push the clutch shell ccw, it would have to lock cw. Is this even possible? Did they sell me the wrong bendix gear? This is nuts!
Old Jun 13, 2018 | 10:13 AM
Tom84FXST's Avatar
Tom84FXST
I have seen the long though bolts rub into the coils inside starter...the starter would work...but had no power.
Old Jun 13, 2018 | 10:19 AM
Jackie Paper
If like an 04 starter, the gear drive is a spur clutch. It is drive always. What happens is if the gas motor start and you do not let go of start button, or heaven forbids, the starter solenoid welds in (happens) the spinning primary spins the starter gear fwd which runs the drive roller pins up a ramp where they freewheel with a loud click hum. This prevents blowing the windings out of the armature and locking all up. So make sure it lock on the way it turns your gear. Once running, then the big gear runs away (out runs) from it.
Rusty Axle
Shovelhead
Nov 4, 2017 01:39 PM
89 FXRS
EVO
Jun 17, 2012 04:16 PM
Jackie Paper
Dec 15, 2011 01:16 PM
bob
Mar 27, 2005 02:09 AM
