Inner Primary question
Old Apr 10, 2019 | 06:49 PM
mike405's Avatar
mike405
Default Inner Primary question
Can anyone tell me if the two washers that go behind the inner primary cover and the front tranny mounts are of a specific size? The primary didn't have any there and in the manual it says to make sure to retain those two washers.
Thanks
Old Apr 10, 2019 | 07:16 PM
johnjzjz's Avatar
johnjzjz
you need a part number and what bike are you talking about 4 or 5 speed and a tin primary has a couple washers for the spring bolts
a little light on info
Old Apr 10, 2019 | 09:16 PM
mike405's Avatar
mike405
Sorry, it's a 1983 flh police bike, it has an aluminum inner primary cover, 4 speed. I have not found any part number. Manual says "the two washers that fall off when you remove the inner primary belong on the two transmission to primary cover studs."
Old Apr 10, 2019 | 09:36 PM
johnjzjz's Avatar
johnjzjz
ok I get it now - the washers they refer too are inside and under the nuts on the studs that attach the back of the inner primary to the transmission
I have always used nylock nuts not regular nuts they come with - to hold the 4 in place - and I use flat or lock washers - then in the front you also have 4 bolts and the inside bolts behind the alternator drum have a safety wire run between them or a lock tab to bend over
Old Oct 4, 2020 | 09:29 PM
dogfoot's Avatar
dogfoot
Get yourself a “Spare Parts” manual. It is very helpful and gives you part numbers. The parts you are referring to are numbers 14 & 15.
Dog
Old Oct 4, 2020 | 09:48 PM
dogfoot's Avatar
dogfoot
Oops, I was looking up the parts & uploading the pictures when he posted it is an FLH. Should be similar to the FX ?
Old Oct 5, 2020 | 09:57 AM
panz4ever's Avatar
panz4ever
Thanks
Mike a similar question just came up in another thread in the Shovel section. There are no washers that go on the transmission studs behind the inner primary.
The inner primary goes against the transmission case and should be flat against it. Once it is mounted the flat washers go on the studs and then you install the ny-loc nuts. The flat washers are #14 in Johns pics of the primary chain housing he posted.
And yes the FX inner primary is "basically" the same as the FLH inner primary (mid-control parts being the primary difference).
Khshockey44
EVO
May 2, 2015 08:40 PM
bipolarsporty
Sep 6, 2013 11:35 AM
chevypilot
Mar 21, 2013 05:12 PM
QuickSilver74
Feb 16, 2011 10:53 PM
HOGRIDA_06
Jan 4, 2010 09:42 AM
