new lifters
Old Aug 31, 2019 | 12:05 PM
larry petersen's Avatar
larry petersen
Default new lifters
I;m installing new hydraulic lifters in my 76 shovel 84in. the lifters are new do I still turn them down 24 flats. Looking in the manual doesn't tell me much; or would solids be the way to go??? thanks
Old Aug 31, 2019 | 12:17 PM
Scarydog's Avatar
Scarydog
I believe so. Make sure to soak in oil and are primed.
Old Aug 31, 2019 | 03:18 PM
jfcroni44's Avatar
jfcroni44
Check this video out.
Old Aug 31, 2019 | 03:47 PM
TwiZted Biker's Avatar
TwiZted Biker
Flat's depend on whose pushrods you are using unless the lifters come with specific instructions otherwise.
Old Aug 31, 2019 | 04:09 PM
johnjzjz's Avatar
johnjzjz
urns - 18 the thread determines the amount of turns down - 18 24 32 48 threads per inch all have different adjustments - picture up the push rods you now have so we can see if they are stock
Old Aug 31, 2019 | 05:46 PM
Bumpandrun's Avatar
Bumpandrun
Whats a good hydraulic lifter for these motors now...used solids in my younger days ....they all sucked lol
Old Aug 31, 2019 | 06:49 PM
johnjzjz's Avatar
johnjzjz
S&S had sold shovel copys of oem lifters dont know for sure they still do
I have used the china ones from v twin and so far they have held up in bikes being ridden 3 or 4 years
the v twin ones use a peddle valve like a evo or two cam lifter and are one piece and fit with oem push rods
Old Aug 31, 2019 | 06:59 PM
TwiZted Biker
Vulcan makes a decent set but you have to use their lifter blocks, won't fit OEM
Old Sep 1, 2019 | 05:01 PM
Bumpandrun's Avatar
Bumpandrun
Want to use my stock not chromes blocks....now come to think of it i dont think i saw the oil passages plugged....
Old Sep 1, 2019 | 06:55 PM
johnjzjz's Avatar
johnjzjz
but they might have drilled the cross holes to the bottom to open the drains to rid the tubes of excess oil - we 8/32 those and drill the centers of the socket head screws to go back to keeping the oil in the block for the hyd lifters
