flh 4 speeds
Old Jan 12, 2020 | 12:10 AM
john lee's Avatar
john lee
Originally Posted by Racepres
^^ That is my assumption... But never bothered to try an interchange...
do you know if the early and later 5sp trapdoors are the same set up thanks
Old Jan 12, 2020 | 08:56 AM
Racepres's Avatar
Racepres
Changed in 1986 and then same from then on... I do Not know what changed!!!
I think the Jims door interchanges tho... So... Research is gonna be necessary!!!!
Old Jan 12, 2020 | 01:31 PM
johnjzjz's Avatar
johnjzjz
the early outer cover and the door are different as well as the bearing end spacers butwe use to convert them as the left side clutch cable would always burn on the jug and when hot roding the engine the heavy clutch spring and clutches let us use the easy boy for the lever feel to be easier
Old Jan 12, 2020 | 01:36 PM
glenny49's Avatar
glenny49
Originally Posted by johnjzjz
we used a double battery at first then when these came along - 500 amp lithium battery and the electric motor they sell - its clean and the bike can be sold separate then the car to re coop as together they are not as sellable as apart and you don't get as much
Johnjziz,I like to know if i may what reverse system are you talking about here exactly,battery,electric motor i assume,but which one. Can i find this on the web?I once saw for sale a sidecar rig with an electric motor and drive gear on sidecar wheel,it looked like a good setup and they said it was a $1400 usd option.I was wondering if we're talking about the same thing here.
Old Jan 12, 2020 | 01:57 PM
johnjzjz's Avatar
johnjzjz
more then a few companys make back up motors for not only side cars a guy is selling one for a dresser - the honda gull wing has one on it as its a tug boat
do some asking around and web searching e bay and side hack sites this site has one as well as starter bike healer kind of thing
in a shop we have the customer chase the hours finding the odd stuff I cant I am already at 75 hours a week normally
Old Jan 12, 2020 | 06:37 PM
glenny49's Avatar
glenny49
Ok,thanks Johnjzjz,i also like your input about the Andrews A2 camshaft
Old Jan 12, 2020 | 07:15 PM
johnjzjz's Avatar
johnjzjz
more then a couple of guys on the site have installed it and are happy they did
Old Jan 15, 2020 | 04:05 PM
jdmboyd's Avatar
jdmboyd
johnjzjz,
Question re the Andrews A2 for my '80-80: Is this a simple drop in or are there head/valve lift issues that need to be addressed?
Thanks for your help.
John
Old Jan 15, 2020 | 05:00 PM
johnjzjz's Avatar
johnjzjz
the engines of that time period if they have not been Professionally re done in a top end over haul and the valve guides replaced with the correct ones then the answer is no
what they did is they used longer valve guides so they could not use valve guide seals - a bean counter cost cutting idea < it did not work out in the end as the engines smoked at 15 ,000 miles - and on the internet some one has an original set of guides with 100,000 miles and it still don't smoke < yea Shure you do
Old Jan 15, 2020 | 05:04 PM
johnjzjz's Avatar
johnjzjz
its the valve travel oem cam .390 lift - the A2 is .450 lift - the top valve spring retainer will hit the guide with the 450 lift cam
tom13
Shovelhead
Apr 12, 2017 08:59 AM
LDB187
Shovelhead
Jan 16, 2013 08:35 PM
john1dup
Shovelhead
Mar 10, 2012 12:55 PM
john1dup
Mar 3, 2012 06:36 PM
Schlebusch
Shovelhead
Aug 27, 2007 09:27 PM
