carberetor
Old Apr 8, 2020 | 11:04 PM
1981 suprglide's Avatar
1981 suprglide
Default carberetor
let my bike set for about three months now my carberetor won't stop over feed gas to the cylinders will appreciate any advice
Old Apr 9, 2020 | 01:49 AM
panz4ever's Avatar
panz4ever
If I read this correctly you have a float that is sticking
Old Apr 9, 2020 | 05:44 AM
Locomotion's Avatar
Locomotion
Sometimes tapping the fuel bowl with the handle of a screwdriver will cause the float to move and shut off the gas. You may have to drop the fuel bowl and replace the needle and seat, and set the float height to specs.(usually done with carb off so it can be turned upside down for proper set) Carburetor
Old Apr 9, 2020 | 07:13 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Couple of questions?. Did it run like this before you swapped out the cams and what is the compression ratio on the motor?
05 Sportster - 1200XL
Jan 29, 2016 11:38 PM
Renback
Jul 7, 2010 02:43 PM
acedantinne
Sep 1, 2007 01:31 PM
pinhead
Nov 8, 2006 10:43 AM
Crimson
Sep 13, 2005 05:30 AM
