keep hearing
Old Apr 18, 2020 | 08:36 AM
FL54's Avatar
FL54
Case in point. Woke my ‘67 FLH from her winter hibernation. She started up fine as she was on a battery tender. Checked the tire pressure and oil and took her for a short ride. Got a 1/4 mile away and she died. As soon as I turned the ignition switch on, the circuit breaker would trip. Walk home and get the trailer and get her on the lift. It took most of the following day to trace down the short that turned out to be bared wire to the turn signals on the terminal in the nacelle. 57 year old wiring combined with the vibration a shovel produces is bound to cause some problems. Don’t they make anything that lasts anymore?
Point is you do what you can to maintain these pieces of history but you’d better have the knowledge and the time to resolve the problems that are bound to pop up.
Old Apr 18, 2020 | 09:03 AM
johnjzjz's Avatar
johnjzjz
het twist its a sparkly redhead and a bottle of Jameson 1/2 gone
Old Apr 18, 2020 | 01:17 PM
TwiZted Biker's Avatar
TwiZted Biker
Cheers to that one, think we're all gluttons for punishment god knows I am in both departments
Old Apr 18, 2020 | 01:32 PM
Uncle Larry's Avatar
Uncle Larry
Someone mention "redheads" ???
Old Apr 29, 2020 | 03:26 PM
mr-stabby's Avatar
mr-stabby
cheers guys ,, i have a 2 mates with shovels and they wear rose tinted specs where their bikes are concerned and to be honest i dont hear about them going wrong too often ,,i was looking for a 78/79 bike and im not too fussed as i have ideas ..
Old Apr 29, 2020 | 03:35 PM
TwiZted Biker
You have the chops for a shovel they can be a world of fun and satisfaction. Rode hell out of mine for 30 + years before I bought a newer bike
Old Apr 29, 2020 | 08:25 PM
SparkyD's Avatar
SparkyD
My '79 FXEF is my first Harley. I knew when i paid an outrageous amount of cash for it ($250 ) and because I've watched the previous owner work on it that it needed a LOT of attention. I love tinkering/building/fixing/repairing things and in the process of rebuilding this thing from the ground up (except transmission . . . ) i fell in love with it. Can't match the amount of fun i had with all the learning these guys helped me with. Nothing rides like a shovel!
GET YOURSELF A SHOVELHEAD!
Old Apr 29, 2020 | 08:41 PM
garystaven88's Avatar
garystaven88
Originally Posted by mr-stabby
im looking at the 1200 shovel if that makes any difference,,
I wouldn't limit yourself to a 1200. The 1340 will broaden your search and some of the later models came with some cool upgrades.
Be realistic in what you want out of a Shovelhead. It won't be your main ride it sounds (you have the FXR) so that IS a plus. I had a skewed perception when I bought mine that I would be rolling 85-90 on the highway riding with TC baggers for hours on end. Yea.... NO! I changed my riding style quickly and learned to ENJOY the ride. Screw all that highway crap.
I don't think the Shovelhead engine itself is what gave the bikes a bad reputation.... it was everything around it. The transmissions leak due to wearable bushings, the starter setups are crap, tapered shaft clutch setups are ehhhh, inferior brake setups, subpar wiring....
BUT, guess what? Everything I mentioned, has an aftermarket FIX/UPGRADE offered by several reputable companies to overcome those shortfalls which makes these bikes so great. These upgrades are not easy nor cheap but they are available nonetheless.
You currently just happen to own a bike which HAD all those updates from the factory and then some.... but it still will never be a SHOVELHEAD (you have an FXR though so you get a solid pass in my book).
They are good motorcycles to invest in and enjoy.... I can think of many other motorcycles which are far worse AND lack the aftermarket upgrades/support.
Old Apr 29, 2020 | 08:46 PM
not_so_newb's Avatar
not_so_newb
FL54 brings up a good point . shovels vibrate a lot more than newer bikes . part of your regular maintenance will be making sure fasteners are tight so stuff doesn't fall off as you ride down the road .
Old Apr 29, 2020 | 09:21 PM
coax9952's Avatar
coax9952
Yeah, Loctite will become your best and closest friend.....
